Question about Hitachi 53UWX10B 53" Rear Projection Television
Convergence i.c. board
Can i please get the web site to buy the part for my hitachi 53UWX10B
  • Hitachi Master
  • 8,617 Answers
Yes, you need two convergence ICs for your model STK392-110 heres the link to the site.
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
We have an 80's hitachi mts 52" tv/ monitor and it has a 3d effect how do we fix this?
Tv have a problem known as convergence problems,it dead.Tv R,G,B colors lines mis alignment,Colors shadows or 3d pictures effect.The tv convergnce board is dead.The tv convergence board,require replacing 2 STK convergnce ICS and some or all it resistors.To solved tv convergence board,to solved tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
DP14G BOARD
Part Store is good choice to get many kind of TV boards.
Check required board there please.
Sep 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
My screen slopes from one side to the other on bottom!
Convergence on ur tv are dead.Must know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to fix it urself.The shop will cost u $300 for parts and labors.
Mar 25, 2010 | Hitachi 53UWX10B 53" Rear Projection...
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 10, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Ineed to know what convergence ic's are in this tv
Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 17, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Convergence cutting in and out
Good Day, Armenian;
You have poor connections on the convergence IC's , re solder and your TV should be back to normal.
Good Luck, big IRISH.
Aug 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b
I believe you can order the convergence board replacement for $299 from Part Store, here's a link to it for my 61" Hitachi, which should use the same board:
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/61SWX12B/Hitachi+Ltd/Hitachi/CS00452R/New.aspx
They offer a 30 day hassle-free return policy, so if for some reason it wouldn't work for you or isn't the right part, all you'd be out is the return shipping, as the initial shipping is free.
I'm in the process of having my board fixed w/the IC/resistor kit and hopefully I don't need a whole new board.  We'll see, but give this a shot, I don't see how you can lose...  -TD
Mar 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b template
Hi, first what exactly are you looking for? the convergence board of the STKs number? If you have convergence problem, you will need to change the STKs for sure and check the resistence to the STKs and generally all of them have same low value. check it out and replace the faulty onces. switch on and adjust convergence and you have a good working picture on the screen. Visit www.fixurtvs.com for more FAQs.
Jan 11, 2008 | Hitachi Televison & Video
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
