My Lexmark - printer,scan,copy,fax- stopped printing and died completely, smelt like power source on back of unit burnt out?? Is it repairable?
  • jpbm Apr 29, 2008
    was hoping I could get away with it cheaply, probably just dreaming!!!
  • 62 Answers
Yes, it repairable, but keep in mind how much did the printer cost over the repiar cost, some times it is better to replace the unit than repiar it
Posted on Apr 29, 2008
    Genius:
  • 3,587 Answers
Maybe...if it cooks, it's time to start looking for another printer..probably the internal control board fried.
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
THE DOCUMENT WILL SCAN INTO THE SCANNER BUT WILL NOT COMMUNICATE WITH THE COMPUTER HOW CAB I GET IT TO GO TO THE COMPUTER?
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
Sep 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My lexmark 2350 will not scan, it will print and copy but not scan. i have had it set up and successfully scan on this computer previously
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/qQJd8g. Select your operating system, download and execute the file.
Aug 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
I cannot use the scan function on my X5470--specifically, to scan documents into PDF format. "Cannot retrieve Application List" is the messge shown. How do I repair this function?
Make sure the Lexmark OCR scan software is installed on your computer. The software allows you to scan your documents to PDF file. The software is only available on the installation disc that came with your Lexmark printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x7170 all in one won't copy or scan starts to but stops
It could be a scanner hardware problem. Try to unplug the printer from the power source to reset it. Wait at least 10 seconds and then re-plug the printer back into the power. If problem continues, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Jun 29, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I need to know how to remove my info from my lexmark 4270 series before I trade it in.
1.Disconnect the power cable from the back of the printer.
2. Hold down the Stop/Clear button. (To the right of the Black Copy button.)
3.While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
Thanks for using Fixya.
Feb 27, 2011 | Lexmark X4270 All-In-One InkJet Printer
Does the Lexmark X1270 Fax as well as scan? I don't have the instructions??
It is a multifunction unit, it will scan,copy,fax and print. Here is the user manual:
http://www.lexmark.com/publications/pdfs/1200/eng/ug.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | Lexmark X1270 All-In-One InkJet Printer
No power on my Lexmark X8350
That's the same printer I have.
First, make sure the blue "copy" button is lit. Printing is done there.
Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
If all these things are right, you should be able to print a test page and the computer should work fine.
If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
Sirwriter
May 14, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark x7350 will not scan, fax or copy
If under warranty contact mfg for warranty repair locations
Sep 09, 2017 | Lexmark X6170 All-In-One InkJet Printer
56 people viewed this question
k24674
jasbo
jasbo
