Back to:
Tags:
Sony FD Trinitron WEGA KV-20FS120 20
Compatibility of TVs sold in USA for use in So...
posted by owl61 on Apr 29, 2008
PAL systems, etc...WIll a tv now sold in USA function properly in So AMerica ( Argentina) ? Does it matter if the signal is provided by cable or satelite?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 29, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2428 votes
Offhand no, conventional US TVs are designed to operate on NTSC whereas to my knowledge, Argentina uses PAL.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Compatibility of TVs sold in USA for use in So AMerica:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Sony FD Trinitron WEGA KV-20FS120 20" TV
Guys,Thanks for your help. The fuse solution was not the...
blinking picture, began as occasional now all the time....
my tv, takes 30 minutes before it open, need help what...
standby light is blinking in pattern of four
tv sony
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
