Question about Sony KP-46WT510 46" Rear Projection HDTV
KP46WT520 TURNS ON BUT ONLY SHOWS RETRACE LINES
ONLY LAST 30 SECS.
    Genius:
  • Sony Master
  • 1,673 Answers
The question is very vague, and there are many things in the TV set that can cause this. In most cases the power supply is going in to protect mode because some components in one of the areas is going too far out of specs and causing some kind of failure. The power supply is shutting down to protect the set set as best possible.
It will take an experienced tech with the proper facilities to diagnose the fault, and determine the failed components that are at fault. In many cases with these sets, they will have to change a complete circuit board to service it.
Jerry G.
Posted on Apr 29, 2008
Picture up side down vertical retrace lines
Upside down picture is due to the connection reversal to vertical scan section winding at the deflection yoke.
If you wish to know more about retrace lines, and the repair work to it; visit this site. http://electronicshelponline.blogspot.com/
Reasons for retrace lines are given with illustrations.
Mar 30, 2015 | Televison & Video
The oven turns its self ON every 20 to 45 mins. The electric ignition glows and the gas comes on and burns for about 30 to 60 secs then turns off. The oven control knob is turned OFF. There are no aut
Seems to me you have a defective control panel board.. Ovens should never do this. Time for the Serviceman right away, this could be dangerous if you are not home.
Nov 24, 2014 | GE Kitchen Ranges
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
Car starts and turns right off
put the key into the trunk lock and turn/hold over to the left OR put the key in the drivers door and hold over to unlock,windows go down.wait 30 secs then turn/hold over to lock,windows go up,wait 30 secs then press the unlock button for 30 secs on the remote,then try starting the car.
Jan 08, 2011 | 2000 Volkswagen Beetle
Tv turns off and on by itself. when turned off, it shows bands/lines of color. what could be the problem?
high voltage regulation problem. when high voltage gets too high protection circit kicks in and shuts off tv. since high voltage is too high, you will see a glow with horizontal retrace lines. if you see red, green, and blue lines your convergence ic's are overheating. suggest local service center
Nov 10, 2009 | Televison & Video
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Switches off after 3 to 4 secs--little bright screen hor line and small retrace lines
On the my sony website, they said try unplugging the set for 3 or 6 minutes. Then plug it directly to the wall. If that don't work, and it won't; seek a service center. I have the same problem.
Next time we better buy Panasonic. Sony products fail ALOT. I had a 5 disc DVD Changer and it was defective and it was part of a class action lawsuit,
I believe this is the same sort of problem.
The sony Vaio laptop computer gets consistent poor reviews.
I brought an alarm clock and its back up battery never worked right out of the box.
I brought a cordless phone and the LCD display went blank.
I am so DONE with Sony.
Good name; Bad products.
Aug 23, 2008 | Sony KV-24FV12 24" TV
Retrace lines and poor convergence
you have bad solder connections on the convergance board solder then and get back to me k
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
