Question about Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 6520 enabling voip connection to yahoo voice
Could somebody please advise me what I need to enable a yahoo voice voip phone service via my speedstream 6520.
    Sergeant:
  • 264 Answers
You should log on to the GUI mode of the Router. There you should find the settings for the VOIP.
Also check this link and you should get the infor specific to the Yahoo VOIP
http://voice.yahoo.com/
Posted on Apr 29, 2008
    Novelist:
  • 119 Answers
Dear yohwayne
I am afraid that there are incompatibilities between speedstream 6520 and Voip service. I will need to look at this a little bit further but I think the only workaround is a firmware update. (modified version of the original)
Regards
EngineerGR
  • 2 more comments
  • T.M.
    T.M. Apr 29, 2008
    Dear yohwayne
    Can you please tell me your ISP service provider. I am speculating that the ISP may have blocked your wireless router from voip service.
    Regards.
    EngineerGR
  • T.M.
    T.M. Apr 29, 2008
    Well even when we dont know yet your ISP we shall certainly need to
    setup the voip service as you will have have the following data available to port forward these ports for voip data. (app 30kb/sec each way) for the SpeedStream 6520.
    Go to the
    ADVANCE tab
    then select
    APPLICATION - PORT MAPPING SETUP
    select protocol UDP
    and
    forward the ports between 5000 to 5060
    Then select the option to 'Redirect selected protocol/application to IP Address' and
    Then enter in the static IP of your phone.
  • T.M.
    T.M. Apr 29, 2008
    Dear yohwayne
    The ISP service TADAUST is offering this particular plan for broadband.
    TAD Super
    256 / 64 kbps
    12 GB
    $29.95
    The reason that I am telling you this is because the download speed required for voip service is at least 512/512 kbps (estimate an average 300/300 kbps
    (30kilobytes/per second) to make it work from your end to the other and
    backwards) If the speed is not enough the line will suffer cuts and
    breakouts.
    Therefore even if we set this system up it may be too slow to be able to have any functionality for telephony service.
    Can you please verify with me that this is the plan you own?
    Many regards
    EngineerGR
    *Please also try to answer at the 1st post you have written as it is
    impossible to follow any traceability with new posts. :) (Thanks)
  • T.M.
    T.M. Apr 29, 2008
    Very important addition:
    Also the TADAUST ISP is based on using the telstra ADSL network which is providing the SIEMENS speedstream 6520 with disable voip capabilities..
    This means that also the firmware of this router/modem has to be changed to be able to use voip service.
    These are not good news for your requirements and I suggest calling your ISP to verify my words and ask for a possible workaround to this issue. If these are not solve please dont proceed on buying a yahoo voip service as it will be unusable and a waste of money.
    Many regards
    EngineerGR
What are the advantages of SIP for VoIP?
SIP (Session Initiation Protocol) is an application layer protocol that is based on IP. It is a major communication standard mostly responsible for VoIP (Voice over IP) telephonic system. In the traditional phone networks, ISDN (Integrated Services for Digital Network) is considered as the communication standard designed for the transmission of voice traffic. Both ISDN, and SIP are usable with equal reliability; however, in ISDN system, the clients need to pay for the data service, and voice service separately, while in the SIP system there is no separate charge for data and voice. Thus, SIP is just good for the customers as it decreases the telephone charges drastically.
Reliance Global Call-Enterprise is one of the most reliable and popular SIP trunk providers over VoIP. It helps to install SIP trunk at the organizational levels, enabling to cut international call rates like local calls. Moreover, the users can connect their landlines, as also mobile lines with the SIP trunk service for VoIP.
Feb 22, 2017 | The Computers & Internet
What is a VOIP connection?
It stands for Voice Over Internet Protocol. Basically your phone system connection is going over the internet. Definition here: http://compnetworking.about.com/cs/voicefaxoverip/g/bldef_voip.htm
k
May 12, 2014 | HP 1040 Plain Paper Inkjet Fax
My problem is that I have just purchased Vonage as a VOIP phone line. I have a HP LaserJet 3055 printer/fax and I am trying to send faxes but it does not work. I was instructed to lower the baud rate,...
Configuring the V.34 setting to Disable (Enable is the default setting) to lower the speed.
Voice over IP (VoIP) services provide normal telephone service, including long distance service through a broadband Internet connection. These services use packets to break up the voice signal on a telephone line and transmit it digitally to the receiver, where the packets are reassembled. The VoIP services are often not compatible with fax machines.
If you continue to have problems faxing, contact your VoIP provider. Because the installation process varies, the VoIP service provider will have to assist in installing the all-in-one fax component.
Although a fax might work on a VoIP network, it can fail when the following events occur:
• Internet traffic becomes heavy and packets are lost.
• Latency (the time it takes for a packet to travel from its point of origin to its point of destination) becomes excessive.
Feb 15, 2011 | HP LaserJet 3055 All-In-One Printer
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
Nat problems cant change my nat 3 to nat 2 or 1 on my ps3 1 tried everything i have siemens speedstream 6520 router
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
My Speedstream 6520 restarts itself
have a speedstream 6520.got a wii at home,wouldnt connect to the internet,need to access WEP nuber.where do i find it?tnx
Apr 10, 2009 | Computers & Internet
Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
Jun 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Voip and speedstream 6520
hi, XBRMann
re 6520 seimens wireless modem
i have DSL internet connection
when the phone call dies i hang up the phone and call again for the same amount of time 3mins and 18 secs
i am using the seimens modem/router with the voip adapter connected via ethernet cable
i have updated the seimens modem/router with the latest firmware from the telstra site E752-AF5-106-71-a056-v1s
lkratzma
Jan 28, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 5100
The underlying Ethernet connectivity required for the broaband connection was not found. Please install and enable the Ethernet adapter on your computer via the Network Connections folder before attempting this connection.
If u don know to install the ethernet adapter pls do contact your vendor
Jan 21, 2008 | Efficient Networks SpeedStream 5100 Modem
Siemens SpeedStream Modem (4100) (SS4100) Logo
552 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
