Question about Acer Veriton 3600G PC Desktop
Replace CPU Heatsink and Fan
I need to replace the CPU heatsink and fan on my Veriton 3600G but don't know the specs for doing this? Can someone tell me what socket type etc so I can buy the right product that fits the 3600G.
  • 77 Answers
Go here:  https://secure3.tx.acer.com/FindSystem/FindSystem.aspx?title=Information%20About%20Your%20System
That should tell you all you need to know about your Acer (as a quick google of Veriton 3600 brought me to Acer).
Posted on May 01, 2008
    Problem Solver:
  • 13 Answers
Really, you should go to the Newegg.com web site. It's very good and have competitive prices. You'll find great descriptions, plans, etc for your system. You can get your CPU heatsink in one day! Every component has specs to tell you what socket type and products that are compatible with a system.
Posted on Apr 29, 2008
  • 52 Answers
Okay as long as the heatsink fits it will work. socket type is for the processor. also dont forget the thermal paste. look up www.ribbitcomputers.com
Asus m32 loud fan
Fan speed does increase for a reason.....heat. Check you BIOS settings and verify that the CPU temp is not getting too high. Desktop computers are dirt magnets. It is common for the CPU heatsink to get clogged with dust and dirt. This will reduce cooling and increase heat, eventually to the point that the fan will speed up. Get some electronic duster (canned air) and blow out the fins on the CPU heatsink. DO NOT remove the heatsink from the CPU. There is a special compound that is on the heatsink surface that allows proper heat transfer from the CPU. Removing the heatsink means that this compound is disturbed and would need replaced. Most users do not have this compound and thus should not remove the heatsink to clean. If the heatsink is so clogged that you cannot get the dirt out with canned air, you may be able to remove the fan from the heatsink, depending on the fan/heatsink design. Then you can use a brush to get into the fins to clean them.
Apr 18, 2015 | ASUS Computers & Internet
How to recover my intel pentium D 2.8ghz processor its over heating of 70 degrees.
If your system is five years old or older it is possible that the thermal grease/tape has dried and will need replaced. There is no need to remove the CPU for this. If you can enter your bios you can also check the fan speed of your CPU heatsink fan rpm. It should run between 2800rpm and as high as 3500rpm. If its not than replace your heatsink assembly.
Replacement heatsink assemble;
http://www.thefind.com/computers/browse-install-intel-cpu-heatsink
Thermal tape: http://www.crazypc.com/products/PQ5-5025.html
Thermal grease: http://www.newegg.com/Product/Product.aspx?Item=N82E16835100302&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-CPU%20Thermal%20Paste%20/%20Grease-_-MASSCOOL-_-35100302&AID=10440897&PID=1609763&SID=tfc_-_4_104_100921_e4d0767819e4422998638af41543c991:0000
Video how to remove heatsink assembly video how to replace heatsink assembly: http://www.youtube.com/watch?v=G3k9Ube9BBs
There are more videos listed on the right side of YouTube.
Good luck.
Mike
Sep 22, 2010 | Computers & Internet
My computers turns off by itself after being on for a while. what to do?
The computer will shut down if the CPU overheats, this is known as thermal shutdow. If this is not fixed, eventually the CPU will fail.
This problem is caused by either a faulty CPU fan or the CPU fan and heatsink are clogged with dust.
Check the CPU fan, if it doesn't spin freely, then replace the fan.
If the fan and heatsink assembly is clogged with dust, then remove the dust and blow the dust off the heatsink with a can of compressed air.
Sep 20, 2010 | Computers & Internet
I have ASrock P4vm800,Prescott800,Pentium 4 Pro.But i need a help.When it is powered up nothing happenes except the system unit ligth up,& chassis font panel ligth is blinking Continously.Cpu fan...
There is a verity of things you can check & or replace. You mentioned the CPU fan is not turning. This is very very important.
This suggests possible CPU fan is defective. Average life span for a CPU fan is 5 years or 50,000 hours. Your MB uses Intel PGA socket 478. For a replacement heatsink & fan assembly open the link provided;
http://www.amazon.com/Thermaltake-A4012-Cooler-Intel-Socket/dp/B000FEW8JW/ref=dp_cp_ob_e_title_0
A new heatsink assembly will come with a new fan attached to the heatsink.
It should also come with new thermal past or thermal tape attached to the bottom of the heatsink assembly.
As to the front panel LED light blinking continuously.
If the LED light is red in color this means your primary hard disk drive is trying to load windows.
My suggestion is for you to replace the CPU heatsink assembly first.
No need to remove the CPU from its socket at this time.
If you never replaced the Heatsink & fan assembly watch the video included below;
http://www.youtube.com/watch?v=4OB1hxxKdec
Once completed your system should function correctly.
If it doesn't, post you’re finding here & I'll help you further.
Cheers'
Mike
Aug 10, 2010 | Computers & Internet
Cannot remove the fan and heatsink
The heatsink is probably stuck on with the cooler compound. If it's really stuck on, then I would release the CPU brace as well and pull the CPU out with the heatsink. Then carefully wedge something sharpe between the heatsink and cpu, like a razor blade and slowly push the blade through the compound until it's unstuck.
Thanks Mark
Apr 16, 2010 | ASUS P4S800-MX Motherboard
Hi, do you have SONY Vaio VGN-CS Series Heatsink CPU and FAN in stock?
Fixya do not stock components, we only provide solutions to problems.
Sep 14, 2009 | Acer Veriton 3600G PC Desktop
I need to replace the cooling fan and heatsink on my Gateway ML6720. I'm having trouble finding the part. If I can find it, can you tell me how to replace it?
The best thing you can do is replace the fan itself with a like kind of shape and size. I usually do this by going to a computer store with the old fan and matching it up with the ones they have in stock, or measure the size in milimeters and buy one on line. The fan is held on by 4 screws and it is much easier than trying to remove the heat-sink and take the chance of damaging the motherboard. You can just screw the new fan to the old heat-sink and you are done, plug it in and insure the fan is blowing in the right direction and you are done. Good Luck, RAC
Apr 20, 2009 | Computers & Internet
How to replace CPU on HP 6735s
Most likely from the back (the underside) where the fan/s are located. You will need to remove the fan/heatsink to get to the CPU. The CPU is locked in place with a zero insertion socket, you need the turn the locking screw 90 degrees to release the CPU.
Be careful when you insert the new CPU, there is a notch that indicates the orientation of the CPU to the socket.
After installing the CPU don't forget to put some heatsink compound on the CPU before installing the fan/heatsink.
Feb 12, 2009 | HP Compaq 6735s Notebook
ASUS NCT-d
Hi, have you tried removing the CPU and using a Air Jet Spray can to clean all contact pins and pin holes? The problem sounds like a loose chip. So also check all on board chips are seated, including RAM chips. Air spray can be bought from most Computer stores. Goodluck mistyman
Sep 09, 2007 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Acer Veriton 3600G PC Desktop Logo
410 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
