Question about Cameras
I bought a 8gb sd card for my 6.0 megapixel cannon digital camera and when I put it in it says NO MEMORY CARD OR MEMORY CARD LOCKED or MEMORY CARD ERROR.If this doesnt work, I want my money back. I dont have my receipt or event the box, I jut put it in my camera drawer and waited for the 2gb card to be done
  • 41 Answers
The message you are receiving seems to indicate that you need to FORMAT the card for it to be recognised by your camera. Your camera manual will provide instructions for you to do that. Hope this solves your problem.
Posted on Apr 29, 2008
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
I have an 8G memory card that I cannot get formatted for a kodak easyshare DX7590 from a cannon format. What do I do? I've put it in the camera and told it to format it but it won't.
Get an SD card.
The DX7590 works with SD (and MMC) cards. Your 8GB card is actually an SDHC card and thus will not work. You'll have to stay with cards 2GB and smaller.
Jun 11, 2010 | Kodak EasyShare DX7590 Digital Camera
When i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Jan 09, 2009 | Canon PowerShot SD600 Digital Camera
SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Dec 22, 2008 | Kodak EasyShare Z710 Digital Camera
Screen displaying "out of memory"
OK, FIRST OFF THE CARD YOU BOUGHT, IS IT COMPATIBLE WITH YOUR CAMERA? IT'S NOT AN SDHC, IS IT? ALSO, DID YOU FORMAT THE CARD? THESE ARE POSSIBLE REASONS YOUR CAMERA IS NOT RECOGNIZING THE 8GB MEMORY. IF YOU FORMATTED IT ON YOUR COMPUTER IT PROBABLY WON'T WORK IN YOUR CAMERA. YOU NEED TO FORMAT IT IN YOUR CAMERA TO HAVE IT BE RECOGNIZED. DOES YOUR CAMERA WORK WITH THE OLD CARD AND NOT SHOW THE ERROR? ARE YOU SURE YOU HAVE YOUR CAMERA SET TO USE THE SD CARD AND NOT INTERNAL MEMORY? CHECK THROUGH YOUR MENU ITEMS FOR CHOICES. TRY THESE FIRST AND IF YOU STILL NEED HELP, REPLY TO: ARCLIGHT1217. IF THIS IS HELPFUL, PLEASE RATE, THANKS!
Nov 30, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
Bought 8gb memory card - error message
Hi, I suspect that the SD card is to big for that camera as that camera is a lower end camera. You should try the SD card in a camera that is known to be able to handle such a huge card.
Jul 21, 2008 | Panasonic Lumix DMC-LS2 Digital Camera
Memory card
Unfortunately, the A520 does not support SD memory cards with more than 2GB capacity, and doesn't support SDHC at all. (1GB max for MMC cards.) I know memory is much cheaper than when the camera first came out, but in 2005 2GB was about as large as you could get.
Jul 20, 2008 | Canon PowerShot A520 Digital Camera
Cameras Logo
164 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
