Computers & Internet Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 4gb pan driv reading only 16 mb - SanDisk Computers & Internet
Anonymous
Level 2:
New Friend:
  • Expert 79 Answers
  • Posted on Aug 11, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
79
Questions
0
Helped
18770
Points
224
This is because you pen drive is formatted to 16 Mb. So it will show only 16Mbs. To recover your 4Gb you have to partition it using a software.
Think this is helpful !
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
1helpful
My usb shows only 1.96 mb while its orignal space is 4 gb
remember that a memory device needs space in which to operate
so a 4gb stick will have less than the 4gb storage
It is very possible that there is some memory being used that results in the 1.96 remaining
one possible solution is to read the stick and see if there is any files or folders than are required and then reformat it to get back to full memory
Can a 16 mb sd card of a canon zr600 be upgraded to 2gb?
Sure. Simply use a larger card. The ZR600 will work with any SD card. Be careful to get an SD card and not an SDHC card. SD cards go up to 2GB (2000MB) in size. SDHC cards look identical but start at 4GB but will not work with this camera.
How to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Sandisk CF Card Problem
It is locked by the previous device. You are not allowed to use it on other devices
Does the HP 1350 support 4gb MicroSDHC
Memory, std.
2 MB ROM, 16 MB RAM
Memory, max.
2 MB ROM, 16 MB RAM Memory, std.
2 MB ROM, 16 MB RAM
Memory, max.
2 MB ROM, 16 MB RAM Here are the specs:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-238444-410635-12085-f57-306884-306889-306890.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My kisgston usb is 4gb but now its capacity is 400mb why ?
All storage manufacturers do the same. 80 Gb HDD is not 80 X 1024 MB. It is 80 X 1000 MB. Is yours showing 400 MB or 4000 MB? If 4000MB then all is well as per manufacturer's specifications. If 400 MB then there is something wrong. Return it.
1helpful
2answers
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Top SanDisk Computers & Internet Experts
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
