Question about Creative Labs ZEN V Plus MP3 Player
Reset button stuck
I used a paperclip to reset it once, now the reset button is all messed up.
i plug into my computer to charge and the screen flickers at low battery then it charges for a bit, then it goes back to the low battery screen flickering.
I've tried to use a thin staple to move the reset button so it works, but even with the reset button in what i believe is the right place, it's still doing the same thing.
what do i do?
  • 8,596 Answers
Firmware upgrade to resolve permanently (Creative website)
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
My tablet says to enter decrypted password but i never set one up
PLEASE NOTE THIS INSTRUCTINS IS FOR FACTORY RESET
BY DOING THIS ALL DATA WILL BE DELETED
The paperclip is used to activate the reset button in this small hole; You will hear and feel a click of the inside button, in less than 15mm of insertion. Do not force unduly!
1. Insert paperclip, until you hear the click of the button. Keep paperclip inserted, and press and hold the black power button.
2. In about 10 seconds the blue PROSCAN screen will appear. Continue to keep black power button held, and release paperclip.
3. A few seconds later you will see an Android 'guy' lying on his back with belly open, and a red triangle (with !) symbol hovering above his belly. Release power button. This means we are on the verge of being able to break things. Note that after a minute or so, if no further action is taken, the tablet will shut down, and then be restarted normally.
4. Press and hold power button. Insert and remove paperclip. You will see a screen titled Android system recovery. (Note that repeated insertion of the paper clip will alternate the display of the Recovery menu). Release power button.
5. Use paperclip to scroll down the list of options. To reset the tablet, selectwipe data/factory reset. Press power button to make the selection. (If you go past the desired option, keep on clicking, as the selection will scroll back to the top once at the bottom).
6. Once reset has been selected, you are now at the final chance to back out or commit. All the menu items, except for one are labeled No. To commit to the reset, select Yes - delete all user data and then press power button.......FOUND ON ZOLYGON.COM
Mar 09, 2015 | Proscan 8" Tablet with 4GB Memory
My irulu model AX366 screen is stuck and it won't turn off how do I fix it
either wait for it to run out of batteries and then charge it and turn it on again, or press the reset button with a paperclip.
***WARNING***, this reset button might delete all of your data.
Oct 30, 2014 | Tablets & eReaders
M9100 boot ans stuck on android screen
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds.
Debugging mode has to be engaged by running ADB, but becomes quite complex and device specific. Plus it can stop your tablet from working all together, so try this first.
Mar 18, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Touch screen is not working properly
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
This should reset the calibrations to default.
http://www.kocaso.com/troubleshooting.html
Mar 08, 2014 | Kocaso M766 Dual Core 1.5Ghz Dual Camera...
Wantturn on
Support Troubleshooting Guide
Feb 12, 2014 | Kocaso M760P 1.2GHz 4GB 7" Capacitive...
Kocaso m750
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. Support Troubleshooting Guide
Jan 25, 2014 | Kocaso Tablets & eReaders
Kocaso M736 is stuck on the Android screen
Jan 23, 2014 | Kocaso M730w 12ghz 4gb 7 Capacitive...
I bought a dual shock controller but the little reset button at the back doesn't have a button in it, so can't reset. What can I do. The lights are blinking when I plug in the usb cable, but that's it. ...
You need to use a paperclip to press the reset button. Unfold the paperclip and push it into the reset hole which is to the right of the screw above the sticker on the back of the controller.
Once you have reset it, plug in the USB cable and press the round button to sync with the PS3.
Hope this helps,
Chris
Mar 17, 2011 | Sony Dual Shock 3 Controller for...
How do I reset to factory settings how to reset factory settings on tom tom one
Which Model of Tom Tom One ?
XL
3rd Edition
2nd Edition
make sure you're fully charged, remove any optional memory cards (depends on the unit) there should be a reset hole, place a straightened paperclip into the hole and press for 15 seconds.
140/130/125
make sure you're fuly charged, press and hold the on/off button for about 15 seconds until the unit restarts
Mar 18, 2009 | Tomtom ONE GPS Receiver
Frozen screen
On the very bottom of your Walkman, next to where you'd normally put the USB cable on the left side (when the screen is facing you) is a reset button. Hit it with a pin, that should do it :)
Jun 03, 2008 | Sony Walkman NWZ-S616F MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
108 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
