Kenmore Washer 110-91564100 60 series doesn't drain
Hello. Had this washer since it was new, Never had a problem with it till tonight. It gets to what seems to be the end of a cycle and makes, one spurt of water/air out of the tube then nothing. I'm a recently licensed electrician, but know NOTHING about appliances. Can you give me some things to do first?
  • 57 Answers
SOURCE: Kenmore Series 70 Washing Machine - won't drain water
it sounds like the lid switch is bad
Posted on Jun 24, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
  • 686 Answers
SOURCE: Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Posted on Apr 17, 2009
  • 249 Answers
SOURCE: Kenmore 70 series washer will not drain
sounds like the timer to me
Posted on Jun 16, 2009
SOURCE: washer wont aggitate.mah5500bwww
Contact Maytag warranty tell them you need a new motor control board it is very easy to replace this unit, this will solve the problem. If your unit is out of warranty insist they send you a new one this is a huge proble for Maytag they'll send you one at no cost just tell them you've been very unhappy and are considering not buying Maytag,whirlpool in the future.
Kenmore 80 series washer will not drain or spin but will fill up how to fix it
The usual thing wrong when a washer such as the one ya have doesn't spin or drain,it's going ot be a broken lid switch. Its a pretty common thing so i have written this tip of how to check for a broken lid switch, http://www1.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Oct 10, 2011 | Kenmore 24032\24036 Top Load Washer
My 90 series Kenmore washer spins but doesn't
The most likely problem is the drain pump.
Jun 26, 2011 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Kenmore Washer
Larry, tell Mom to check the lid switch. If it's broken there will be no spin or drain..
Jun 13, 2006 | Kenmore 24872 Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
