Just to confirm unfortunately there is no kit available to do what you request. The sensors in all Rinnai heaters are located where the cold air is drawn in to the heater, usually at low level where the colder heavier air sits. I'm guessing you have tried setting the temperature as low as possible when you are out. Basically the solution to your problem led to Rinnai putting timers on heaters so people can set heating times around when they are in or out of the house. Unfortunately there is no way to add a timer to a non-timer unit. Sory for the bad news
