Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire Side by side Leaking water from Behind the dispensor
It was working fine. Then it started leaking water from where the water is frozen almost like it wasn't reading that the trays were full. I turned it off to stop leak and now it won't make any ice when I turn it back on HELP PLEASE
  • greg2ora Dec 10, 2008
    i have the same problem, but how do i take the valve off,,?
  • 828 Answers
You may have a defective water inlet solenoid valve. replace water inlet solenoid valve for ice maker. Contact Frigidaire Dealer for part by Model and serial number. Replacing the part is reverse of removing old valve located behind refrigerator on right side facing the back. You may have to remove bottom back cover to access. Make sure you reinstall the cover for proper operation.
Posted on May 02, 2008
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Apr 25, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
Icemaker inlet tube frozen. No water to icemaker. drinking water dispensor works fine.
If the tube is located behind the icemaker and to the left in the freezer simply either take a blow dryer to it or if you can remove the fill tube manually i would. This happens because your valve is leaking back alittle and if it reoccurs you'll need to replace the valve. Just thaw the fill tube and you'll start working again.
Feb 09, 2010 | KitchenAid Refrigerators
No water at the dispenser
the water reservoir located in the refrig. compartment behind the drawers may be frozen,if nt the water inlet valve may be at fault.it is a dual valve system one side for the icemaker the other for the dispensor
Jan 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
FRS25R4A side by side. Water drips from the water
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 07, 2009 | Frigidaire FRS26R4A Side by Side...
Water Dispensor leaking - HELP
shut off for the water supply igenrelly under the kitchen sink or in the basemant. no need to shut off main water supply to home. only to the unit itself
Oct 27, 2008 | KitchenAid KSCS25FKSS Side by Side...
Water dipenser broke
drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Oct 19, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
202 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
