Question about Panasonic PV-DF2735 27 in. TV/VCR/DVD Combo
Parts While the DVD tray was open, someone walked into it from the side. I removeved the DVD player and I beleive that is broken beyond repair. DO you know where I can get a new DVD playe or can a generic one be adapted Larry
  • 298 Answers
You can get the DVD Mechanism from http://www.andrewselectronics.com. Please see below for the direct link.
Panasonic PV-DF2735 DVD Mechanism Replacement
Posted on Jun 25, 2008
    Sergeant:
  • 291 Answers
Www.partsl.com
1-866-925-PART (7278)
Posted on May 01, 2008
Why won't DVD player open?
Search Results
    How to Fix a DVD or CD Player That Won't Open - YouTube
    ? 4:53
    https://www.youtube.com/watch?v=RcVn9NUtq0c
    Sep 22, 2014 - Uploaded by doityourselfstan
    How to Fix a DVD or CD Player That Won't Open ... Up next. How to repair a CD/DVD drive that won't ...
    How to fix a DVD drive's tray that doesn't open or eject ...
    ? 9:45
    https://www.youtube.com/watch?v=Kl1jB9MJXsE
    Jul 5, 2010 - Uploaded by lowendguru
    This video shows how to fix the tray of a CD or DVD drive when it does not eject ... I have a phillips cd-rom drive and it won't open, I checked the belt and its tight, so I .... Dvd Player Sticking Door Repair And Lens Cleaning.
    How To Fix A Broken DVD Player - YouTube
Dec 08, 2015 | Samsung Televison & Video
Tip
Tips on how to fix the DVD player ( not eject )
You have to check the try loading belt of you DVD. if the belt is loose or broken the will not be ejected. you can see only OPEN in the display. You can simply check is it related to belt. Power on the DVD player and then press the eject button. Place you ear on the top of the player and listen is there is any humming sound (sound of motor running). If you hear the sound then the belt have some problem.if there is no sound then the problem is related to the electronic part which drives the motor. if so you have to change the motherboard of you DVD player. Because the all the parts in it are S.M.D( surface *****device) also the availability of the part is very rare.
If you here the sound then you Can rectify the problem by replacing the belt.Normally you cant see the belt from the top of the mechanism. Because it is beneath the tray. you can see it only if the tray is in eject position.
Remove the top cover of your DVD player. As it is DVD player you can eject the tray manually. for that watch the bottom of your DVD player. You can see a slot closed by a plastic strip just bottom of the mechanism. Pull out the plastic strip. Watch through the slot. you can see a Noach which you can move manually to the left and right. put a screwdriver in it and pull the Noach to the side. the try will get ejected. Not fully but partially. You have to pullout the tray fully manually.
If you closely look at the inner end side of the try then you can see a motor and belt. if the belt is loose it will be in there in the motor pulley and in the wheel. if its broken broken then you have to find it where it . Take the belt as sample and bring a new one. you will get the belt at any of the electronic spare parts shop near you. Put the new belt in the position. insert the tray by pushing it in to inside slowly. power on the DVD player and the press the eject button.
on May 02, 2011 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
How to repair a DVD tray stuck?
Just open it up and have a look, could be some plastic parts of the tray has been bent by someone accidentally pushing it in when locked, or something might mess with sensors telling the unit what position the tray is in.
Jul 20, 2014 | Daewoo Televison & Video
Samsung dvd R155 disk tray won't open/eject
1) try to clean the button with special contact cleaner spray
2) if this work, is o.k otherwise use the r. control and try to open the tray if work, is obvious the button was dirty. If doesnot work, you must the DVD player.
3) inspect any belt and replace, and lube any shaft +gear with small lubricant( vaseline) and replace any parts broken.Tight any wires connector very well and clean it.
4) if doesnot resolve the problem you must go the repair shopt TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
Hi, it is a Yamaha S-550 dvd player the band that controls the dvd tray has broken.
Hello
The tray out part which carries the disc inside and out of your Yamaha DVD player ahs borken I assuses. To repair this, you have either buy the borken part or as its tray mechanism as a whole from the local electronic spare part shops, or from the authorised Service Center for Yamaha at your town. Normally, this part can be bought from local electronic spare part shops, as so many companies use the same model tray mechanism. If you approach to authorised service center, you may have to pay more for the same stuff we buy from open electronic sparepart market.
But, to to disassemble and reassemble the mechanism unit, you must ahve its repair manual with you. I've it with me now, the full repair manual for Yamaha DVD-S 550. It has all the details about its all repair, including schematic diagram and mechanical parts, adjustments, etc. But I can't send it to you by this window as it does not allow me to upload any PDF files by it. Morover, without knowing FixYa, I shouldn't send any PDF files to customers. If you are interested, buy one amoung my DVD service, advertised in FixYa, and provide your Email address to me by it. I'll send a copy of it to you by return mail. OK.
Nov 14, 2011 | Televison & Video
Vcr/dvd combo, dvd drawer stuck open
they are either gear or "belt" (rubber band lol) driven trays the rubber band has slipped off or the gear is off track if your brave and skilled enough just open it up and reset it or fix it if not take it to someone who is
Aug 03, 2009 | Televison & Video
JVC dvd player try is brand new but the tray won't open.
Okay i just bought a new dvd player and the tray won't open and hitting it won't work! can someone help please?
Mar 28, 2009 | JVC XV-N370B DVD Player
H03 Error & Disc Tray Error
Most likely the tray for your player came out of aligment, this happens when someone pushes on the tray to close it, instead of using the "Open/Close" button, you need to take it to somebody to realign the disc tray.
Jun 13, 2008 | Panasonic DVD-RP56 DVD Player
Disk Tray won't open
is there a tiny pinhole to push in a paper clip to eject the tray?
Jun 03, 2007 | Pioneer DVL-V888 DVD Player
DVD Player Tray Broken; Out of its slot
the simplest thing to do is notice where the tray comes to a halt when opened then re-align the teeth with the first in-take tooth of motor this can be tricky if you don't feel like repairing yourself take it to be repaired by a technitian. hope you get this sorted
May 04, 2007 | LG DE9523P DVD Player
Panasonic PV-DF2735 27 in. TV/VCR/DVD Combo Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
