Question about Kenmore 63942 Dryer
Kenmore 70 Series Dryer Won't Heat
My Kenmore 70 Series, Heavy Duty Super Capacity dryer won't heat. Model # 76722695. I've taken off the back panel and vacuumed up all the lint and/or dust accumulation I possibly could. Any suggestions?
  • 3 more comments
  • Anonymous Jun 09, 2008
    Replaced igniter and vacuumed dryer.
  • Anonymous Jun 14, 2008
    idler pully dislodged when belt broke
  • gentis061 Nov 25, 2008
    How do I remove the thermo cupler?
  • Anonymous Dec 27, 2008
    dryer wont heat up what could it be
  • Anonymous Mar 15, 2014
    How to replace the door pressure switch on a kenmore 70 series dryer
Won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Posted on Oct 07, 2008
I have the same problem. Did some research, found the thermal limit fuse is a common failure. Took the back off, found the fuse. No continuiuty (blown). Put a test jumper lead across the terminals--dryer operates normally. Still trying to find the part. Sears website not helpful. Won't accept my model number.
Posted on Jul 15, 2008
My kenmore 70 series won't heat up do I have a piolt on it or is it something else? It runs but i don't get any heat.
Posted on Sep 28, 2008
  • 481 Answers
First check your breaker, turn it off and back on.
Posted on Jun 28, 2008
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Nov 05, 2010 | Kenmore Dryers
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Pressure switch broke off-need help fixing
Sears.com
Parts direct
Look it up by model number
Then part discription
And they will send you the part for a fee
Mar 18, 2010 | Dryers
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Kenmore 70 series dryer leaving brown marks
you can get the parts direct from www3.sears.com and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Jan 13, 2009 | Dryers
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
3,158 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
