Question about Samsung TXL3276 32" TV
Black Square on screen with codes written on the top of it.
What to do when a black square pops up on the screen with codes written across top of screen. Is something going wrong or is this an indication for me to do something for it.
  • blvdg1 Apr 29, 2008
    Well, so far, the black square hasn't re-appeared so I'm hoping it's fixed. Thanks ever so much, meknow!
  • 71 Answers
In menu, turn off cc-closed caption
Posted on Apr 29, 2008
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
On certian channels a big black square pops up and random letters start going across the screen.
Ur tv Closed Captioning is still on like CC 1,2,3 or Text 1,2,3 is on.Look in ur remote control for a button said CC press it make all CC 1,2,3 to all off.Go into memu find closed caption function Text 1,2,3 turn it to all off.These steps,will stop random squares boxes lettering showing up ur tv any channels.
Dec 11, 2010 | Mitsubishi WD-65731 65" HDTV
A black square pops up in the middle of the screen after awhile, what could be the problem ?
How big is this black square? Is it like 1/4 to 1/2 the size of the screen? If so, you probably have Closed-Captioning turned on, and turned on to TEXT mode. Either change it to CC1, or else turn it off, and your black square will go away!
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Black square box pops up in the middle of tv screen.
It is most likely related to the Closed Captioning option on your TV. Go into settings and make sure that CC is turned off, or make sure it's set to CC1. What you are probably seeing is the "text" option included in the CC options.
Feb 14, 2009 | Polaroid TLA-01511C 15 in. LCD Television
My apex gb43hd10 has a black screen square only on cbs.
it is your captions turn captions off how old is you tv is it analog or digital tuner
Jan 19, 2009 | Televison & Video
Fitting instuctions for replacing lcd screen on my samsung e250 mobile phone
ok...
1.take off battery cover, remove battery, memory card and sim card
2. remove the five screws on the back... two at the bottom, two in the middle and one on the mid top right and take off this cover, remember! keep the screws safe
3. slide the phone up and take out the two screws on the left and right paralel with the battery tabs then remove the two screws ether side of the camera...they might be covered by rubber coverings, these pop out easily
4.now you can prise the top of the screen off with a small flat headed screwdriver
THERE ARE TWO OPTIONS HERE, IF THE REPLACEMENT SCREEN HAS NO RIBBON CABBLE ATTACHED THEN FOLLOW FROM FIVE, IF IT HAS ONE CONNECTED THEN FOLLOW FROM
5. its conected to a ribbon cable, remove the tape and slide out the cabble from the screen.
6. now take out the screen PCB from the plastic casing and replace it with your new one and put the ribbon cable in and clip it back together, now reverse stages 3 to 1 to put it back together.
7. if the ribbon cable is attached now you must look at the PCB board on the back for a square copper line, on the left of this there is a big black square just smaller than the copper square, prise this off with your finger nails, keeping it to the side take the PCB up about 2mm and then fold the bottom of it to revele it is conected to a ribbon cable by a bigger version of the black square so prise this off and take the PCB and put it safely to one side.
8. look on the front of the phone under the top bit of the screen, there should be a semi circle in the plastic with a black circle in the top of it, use your nail or a flat headed screwdriver to pop it to the other side of the semi circle, now the slider should go past what it used to o you can slide it up to when you can see the ribbon cable go down through the phone, now push the black square end through and you should be able to slide the whole front off.
9. replace the screen by taking the screen PCB out and repacing it, then thread the ribbon cable back through and slide the front on while making sure the back circle goes into the semi circle and to the top side of it, then thread the black square through the phone to the front and clip the phone front back on.
10. snap the black square back on to the back Circuit then put the circuit back into the phone and snap the small black square back on then go from stages 3 to 1 to put it back together.
this should be fairly easy to do for most people.
Jul 03, 2008 | Cell Phones
Black square on tv screen
Turn off your closed caption...
Bill
Mar 20, 2008 | Televison & Video
Black square
hmmm...the black square syndrome..sounds like the picture in picture settings are unhappy..check those, to see if maybe it's on some sort of timer, and accessing a non channel(which might explain the black square).
Feb 29, 2008 | Hitachi 57F500 57" Rear Projection...
Black square
Your closed captioning is on. Go into your settings and turn it off. some caption modes take tend to do that. My bro had the same problem and it went away with the setting changed
Feb 22, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Black square in middle of tv
He, he. Somebody activated the subtitle mode on the remote. Desactivate the CC mode on your menu and it'll go away or at least if you want CC put it in CC1 Text1
Dec 10, 2007 | Hitachi 50FX20B 50" Rear Projection...
Samsung TXL3276 32" TV Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
