Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony KP-51WS510 When I try to turn on my TV, the sound comes on for a while with no picture, and then turns off and the red light blinks eight times. After reading a little bit it sounds like it is a problem with the power supply. Is there anything I can do are do I have to buy a new part, would this be a difficult fix.
  • tinajeff May 02, 2008
    turn on the tv the red light flashs 10 times and then shuts off.
  • Anonymous May 07, 2008
    i have a 2004 model kpfw51m31 130 cm rear projection that wont turn on it blinks red light 10 times and is really hard to start
  • Sony Master
  • 8,617 Answers
8 blinks in that model means High Voltage Error which means the flyback is defective and will need to be replaced. Sony parts list it as no longer available. But you can get it at the following link for 129.95 and it comes with free instalation instructions. the job takes about 45 minutes from start to finish. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
My Sony TV Model # KP-51WS510 flushing 4 red light or blinking 4 red light again and again, once I turn on the TV power. No picture on the screen and you will hear that it will shut off but the 4 blinking...
Usually a flashing power light on a rear projection TV means a bad bulb, try replacing the bulb. Also try unplugging it for 10-15 minutes, then come back and plug it in and try again. Also if its been a long time since its been serviced it could be dust buildup causing overheating, do you hear the cooling fan running? It could also be a failed cooling fan. Generally the first thing i do with projection TV's is clean them, clean all the vents, pull the bulb out, clean out the cooling fan and bulb housing, and then try a new bulb. If that doesn't fix it then its a bigger internal problem and there is no quick fix but have it serviced.
Jan 02, 2018 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510 blinking light but no picture at all. Audible click like usual followed by another click sound shortly after.
THE click is the relay on the power board coming on and then going off---red power light should blink a error code---when set shuts off (second click) watch the power light and count the blinks.
Let me know what you find.
SD TECH
Jul 28, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony dp-51ws510 made 11-03
If your tv is Sony KP-51WS510, then it has problem in convergence ICs or Board and needs to be replaced.
Best Buy has no idea about Bulb, this TV is 3 CRTs rear projection system and has no Bulb or Lamp inside.
Need further help, let me know.
KP-51WS510
I would suggest to turn the screen control potentiometer down a bit, this control is found on the front of your TV nearby the CRTs.
The part looks similar to the picture. Click here to see picture.
The red control is the one on the left if you are facing it.
Let me know if you need further assistance.
Jul 30, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
267 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
