Question about Cameras
I just recently installed my new web cam. I can not open the program. I get an error message that the file Agcgauge.ax' was not found?
  • Scottgil70 Apr 29, 2008
    Philips-WebCam SPC900NC
  • Scottgil70 Apr 30, 2008
    yes I have uninstalled it & reinstalled it twice. no good, any other suggestions? Scottgil70@aol.com
  • 26 Answers
Have you tried uninstalling web cam, then re-installing again?
Posted on Apr 29, 2008
Installation
Hi! don't worry with the driver..you can choose it from here..
just click the file...and click " save " to start downloading....using winrar (and or winzip), extract the file and install driver for your web cam
1. a4tech PK-635 web cam (rar) file
2. a4tech PK-635 web cam (zip) file
But first connect your web cam via usb slot on your computer... wait till a message on the taskbar appear: found new hardware..once ask for a driver.. choose one from the driver and install it.
Just follow this step and your web cam will work again.
Please rate this solution if you successfully installed your web cam....thanks..
May 30, 2010 | A4tech Viewcam PK335 Webcam
How can i install my A4 tech cam in my pc w/the cd
Here's the driver...
just click the file...and click " save " to start download....using winrar (and or winzip), extract the file and install driver for your web cam
But first connect your web cam via usb slot on your computer... wait till a message on the taskbar apper: found new hardware..once ask for a driver.. choose one from the driver and install it.
In a few minutes, your web cam will be working..
May 30, 2010 | A4tech PK-635 Webcam
Window explorer is not working on my grandsons lap top when he turns it on the message comes up windows explorer not working
-Try to install from recovery disk your all system back
-If you dont have recovery disk try to restore your system to couple of days back or a month
-When you get the error make sure to look at details
and see the file name mentioned. If the file name is "mpegsplitter.ax", this is because u have installed codecs, could be either k-lite codec or some other. U just need to delete this file, either by going to win xp or opening command prompt in task manager under file, select new task and type cmd. The file will be located in program files, k-lite codec, filters. Just delete this file and restart.
Nov 28, 2009 | HP Pavilion DV2700T PC Notebook
Not enough memory to complete instalation ?
maybe delete some unwanted programs and files off the hard drive you use, you may be out of space on your hard drive
hope this helps, if you need more assistance contact me please.
Dec 03, 2008 | GE EasyCam Pro Webcam
Windows Explorer sends continuously error messages
Turning off thumbnails will probably stop you getting that error
DO:
Open Control Panel > Folder Options > Always show Icons, Never Thumbnails
However, this isn't actually fixing the problem.
Do you have Nero installed by any chance?
If so try:
Open Computer > System Drive > Program files > Common Files > Ahead > DSfilter.
Rename "NeroVideoProc.ax" to "1NeroVideoProc.ax"
Also rename "NeVideo.ax" to "1NeVideo.ax"
And then reboot.
Nov 11, 2008 | Computers & Internet
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Built in Web Cam -
How do I obtain and install YouCam?To obtain YouCam, do the following:
  1. Open an internet browser, and go to the HP website.
  2. Type SP37849 in the search field and then press the Enter key.
  3. Select the search result Cyberlink YouCam Software.
  4. Click the Download only option to save the file to a folder on the hard drive or desktop, then doubleclick the file's icon to begin installation. Follow the on-screen directions to complete the installation process.
Always check to make sure that you have the most recent version of the program, as well as the most recent version of WebCam drivers.
Sep 16, 2008 | Computers & Internet
Camera assistant software not working
camera assistance not working..it says cannot open file corona
Aug 22, 2008 | Computers & Internet
Web cam
check if the internet conection is available while running the setup.
open internetexplorer select tools ,click on delete browsing history,click on delete files to empty temp internet folder.
close any other application while running the setup.
Nov 20, 2007 | Genius VD3000022 Webcam
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
