Question about Sony KV-32FS13 TV
My sony Tv picture has shifted to the left
My TV picture is off center, it seem to be shifted to the left about 5 inches. How do I get my picture to slide back to center. I think I have a sony 32" KV-32FS17
My tv is no picture but they have sound & power
Posted on May 07, 2008
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Sony tv picture problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Oct 25, 2008 | Sony KV-40XBR700 40" TV
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
MY TV SONY KV27FS12 PICTURE PROBLEME
Hey Rolly no problem man as if we can help ya your not taking up our time as we answer when we can. Ok theres is still a small cap somewhere by the drive ic or they call it the jungle ic. If you have a schematic scan the vert part and I will assist you the best i know how.
Apr 14, 2006 | Sony KV-27FS12 27" TV
Sony KV-32FS13 TV Logo
315 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
