FixYa.com
Tags:
PNY 4GB Secure Digital High Capacity Memory Card
Unable to access files on the flash drive (by 6 users)
posted by dalangels on Apr 29, 2008
Used the flash drive for digital pictures. When we insert the drive into the laptop, we are unable to access the drive. We have other flash drives that work correctly. Guessing I need a driver but unable to locate one. Any ideas on how to get the PNY flash drive working?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Jul 29, 2008
I am trying to use this card in my PDA phone. I took a 2GB different brand out and put this 4GB PNY optima SD, but it is not being recognized
Comment by aloflin, posted on Jun 30, 2008
Same situation with the 2gb card purchased to use in my NIkon D40. Has worked just fine until yesterday. Right in the middle of taking some pictures it just all of a sudden went blank and read "This memory card cannot be used. Card may be damaged. Insert another card." Tried to read card from several pc's and got nothing. I desperately need help in retrieving those pictures, let alone get this card to work again after 6 months of minimal use!!
Comment by awhjo, posted on Jun 28, 2008
Have photos on a 1gig PNY card The card has stopped working & a message on the rear viewer of the camera reads "card cannot be used may be damaged "
When putting the card into the computer slot the computer wont reconise the card at all
Other cards still work fine
But we need to recover the info
Comment by mreist, posted on Jun 18, 2008
I have a Palm Treo 700W that I use and the SanDisk 512mb SD card works fine. However I just bought a PNY Optima SD HC 4gb card that my phone does not recognize. Do you have anything that I can do to get it to work on my phone?
Comment by Eddie_Ed, posted on May 05, 2008
I have a new laptop. When I put the SDHC in the drive, the drive doesn't respond or read the memory card. I also put it in my USB card reader, and it didn't recognize then either. Can you help me?
Best Solution
posted on Apr 29, 2008
Helpful (85)
bigestalever
Rank:Master Master
Rating: 90%, 11 votes
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Removable Media problems?
Removable Media
Non recognized Kingston...
my Kingston pendrive 4 Gb works... Answer This...
Removable Media
Need Win98 Driver
Helllo, I am hoping you can... Answer This...
Removable Media
Micro SD Card Capacity Error
Hello, I am having a Sandisk... Answer This...
Removable Media
Sandisk Adapter Problem in a HP...
I have a Sandisk 1gb mini sd... Answer This...
Removable Media
driver of sandisk cruzer micro...
driver of sandisk cruzer micro... Answer This...
Repair Service
Find Removable Media Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
