Replace MB on Gateway M280E - Computers & Internet
  • 62 Answers
Power down your tower, then unplug the power cord. Lay the tower on the side and remove the side plate (usally one main screw at the back end of the tower and then slides to the back and comes off) Located inside the tower on the mother board you will see the memory stick. At each end of the memory stick is a little plastic lever that when pushed gently away and down from the stick it will pop up that end of the stick. Repeat on the other end of the stick and then pull the stick out evenly. Take the memory with you to the store so as to get the same kind of memory and also to get the right PIN set. Remember to pay attention to what slot you pull the memory out of. Also keep in mind that you never want to mix memory sticks IE a 512 mem stick with a 256 ect. It is also adviseable to stick with the same manufacture of memory and not to mix and match brands.
Posted on Apr 29, 2008
Gateway TabletM280e screen broken. What is needed to replace and how to replace it.
Assuming the screen is physically cracked, you need to obtain a new screen, remove the screen bezel by popping off the rubber caps and undoing the screws under them. The screen is fixed into position by two rails with small screws holding it into place. Remove these and the screen will be freed.
Disconnect the VGA cable and the smaller two wire plug that connects the inverter to the screen, replace the new screen and re assemble
Mar 27, 2011 | Gateway M280E
Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
Jun 03, 2010 | Gateway M280E
M280E (41891001) Tablet PC: the screen is very dark, cannot adjust brightness...
hp tablet compaq tc4200: the screen is very dark. cannot adjust in control panel, it's greyed out,
May 16, 2010 | Gateway M280E
How do I install a keyboard in a Gateway M280E Tablet? (Directions with pictures a plus, but not absolutely needed.)
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
Apr 21, 2010 | Gateway M280E
The stylus for my gateway m280e is unresponsive, it is able to track the cursor across the screen but it can not select anything when double tapped, or write in one note? What could be the issue?
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select, the "Mouse". In the Mouse, "Properties" (window) change mouse functions. "I hope this "Fix it"
Jan 24, 2010 | Gateway M280E
Install new hard drive m280e
~er~ what do you wanna to say ? how to install new hard drive?
if yes,you can reference the article :Illustrated how to replace a laptop hard drive
hope it can help you
Jan 13, 2010 | Gateway M280E
How to set sensitivity on digital pen gateway m280e
http://support.gateway.com/s/Mobile/TabletPC/3501440/3501440faq33.shtml
try it out once..
Oct 18, 2009 | Gateway M275 Tablet PC
Hi i like to install xp profecianal on my laptop m280e i have on it xp7 tablet ther any probleme to install xp profecianal please responce
XP professional will not work on that unit. The OS will install and work properly but you will lose many of your tablet functions. You have to have the tablet pc edition for all comonents to function. You would not gain anything by going to Pro, and your Windows or Microsoft update will keep your current tablet pc edition updated properly.
Aug 18, 2009 | Gateway M280E
Problem with pen/software on Gateway M280E
First install the anti virus software then update the software then scan your computer after scan try again. if it cant work format your computer.
Sep 03, 2007 | Gateway M280E
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
