Pulses on and off vs35403 - Televison & Video
  • lee martin May 01, 2008
    mitsubishi cs35403 comes on cold, heat it up turn it off.turn it back on right away.it may come on.wait5 seconds at turn on it will pulse on and off. it may pulse on or may stop pulsing for a while and start again.
    i fixed it to day. i had traced the pulsing back to the micro on outpin experience made me doubt micro. the small transistor q549? horiz drive swich seemed too hot it checked good. igot the set to pulsing got the freeze &srayed the the little fellow. the pulsing sped up then set came on. i then replaced it.turned set back on. sam thing again. i then tried heating the the xsistor with my iron.i accidently shorted col.to emitter set came on. i tried set on&off hot &cold. played it all day. tomorrow i will check it out again then i will return it with a slight charge for.extra parts&gas. thanks for your concern
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 30, 2008
I have no injector impluse
no injector pulse - DodgeForum.com
dodgeforum.com/forum/2nd-gen-ram.../269362-no-injector-pulse.html
Nov 21, 2010 - no injector pulse 2nd Gen Ram Tech. ... but was running and driving fine before. as far as i can tell i have no injector pulse. tested with a noid ... No spark AND no fuel injector pulse ONLY when van is cold ...
Nov 18, 2013
2000 ram 1500 Has spark but no injector pulse wont start ...
Jun 25, 2013
v10 RAM no start....frustrated
Sep 19, 2011
help - no spark, no injector pulse, no run
Oct 30, 2009
More results from dodgeforum.com
No injector pulse 02 Ram 1500 - DodgeTalk : Dodge Car Forums ...
www.dodgetalk.com > ... > 3G Dodge RAM - General Talk
May 30, 2012 - No injector pulse 02 Ram 1500 3G Dodge RAM - General Talk
Oct 23, 2015 | Dodge Cars & Trucks
Why is there no pulse at injectors on a 05 mondeo tdci
No pulse? Is the engine running? How are you measureing pulse? If the engine is running there is a pulse, if it's not running, there won't be a pulse. If TDCI is correct this is a turbodiesel
Compression Ignition.
Mar 12, 2015 | 2005 Ford Mondeo
No injector pulse
1991 this make you OBD1 . You can access a code by jumping 2 terminals together.The injector pulse is from the PCM . If you have no pulse you need to troubleshoot for spark first . If you dont have spark do spark first then injector pulse comes on. If no injector pulse check fuse in engine junction box.Use a volt meter check grounds at PCM. If all else checks out good replace PCM. You may also want to check the TPS. If this sensor short out in the WOT position you also wont get injector pulse.SO disconnect the TPS. and recheck for injector pulse
Feb 23, 2012 | 1991 Chevrolet Caprice
I Have A 2000 Hyundai Accent And The Codes P1529 and P0722 Came Up. What Does This Mean. Please Help Me Out.
P1529 - MIL light request
P0722 - Transmission Pulse Generator B. The Pulse Generator detects the revolution of the idler gear parking pawl lock gear and emits a pulse signal. The pulse signal is sent to the Transmission Control Module (TCM) which converts it into vehicle speed. The code is detected when the Pulse Generator B failed to provide a signal to the TCM upon initial movement of vehicle.
Symptoms:
- Engine Light On (or Service Engine Soon Warning Light)
- Speedometer improper reading
- Possible shifting problems
Possible Causes:
- Pulse Generator B harness or connectors
- Pulse Generator B circuit is open or shorted
- Pulse Generator B
Jan 15, 2011 | 2002 Hyundai Accent
Pulse in back petal
most of time when you feel a pulse it the front if you feel the pedal pulse its the rear dont forget when the front is very bad you might feel the pulse in pedal and car cheers pierre
Jun 27, 2008 | 1995 Jeep Grand Cherokee
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Pulse-dialing with Arris modem?
If you have the current firmware for your modem, it should work with pulse. Arris had to make it's MTA's pulse compatible due to old alarm systems that still utilize pulse dialing.
Apr 18, 2007 | Arris Touchstone 450a (CM450) Modem
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Televison & Video Logo
Top Televison & Video Experts
