Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27062600 Fault code 50
Washer starts to fill, stops, fault code 50.
  • 4 more comments
  • Anonymous Aug 21, 2008
    start filling water stops then F 50 shown stop operating
  • margu_26 Aug 21, 2008
    washer starts filling, stops, fault code F 50
  • kathcooney Nov 19, 2008
    midway during the wash cycle the washer beeps & flashes F 51 What is this & how can it be fixed?
  • Anonymous Jan 05, 2009
    F50 Error code just after it starts to rinse. Then it won't spin out at all.
  • Anonymous Mar 18, 2014
    fills just a little then sud would display then f-35
  • Anonymous Mar 28, 2014
    Kenmore elite mdl 110 49962 600
Any solution? I have the same F50 error code.
Posted on May 17, 2008
    Sergeant:
  • 222 Answers
The F-50 code is directly related to the motor and the motor controller board, more than likely you need a motor controller
Posted on Nov 25, 2011
Kenmore Elite Oasis Clothes Washing Machine Model # 110 27032603 Stop Running while Filling w/ water Flashes Error code F 50
This is a no motor movement fault, This could be due to a fault with the RPS (rotor position sensor) or the machine electronics but either way would require an experienced person to repair.
Mar 05, 2012 | Washing Machines
F1 flashes on my maytag bravo washer
This is an inherent problem with this Whirlpool-made top load washer and at first it is believed to be a machine/motor control fault. But it was found later that it can be due issues associated with the pressure transducer/switch system. Air leaks and moisture in the pressure hose including lints or flashing in the air dome can lead to signal error being sent to the machine/motor control assembly and it is interpreted as a machine/motor control fault. You may also observe that the fault code F1 appears usually during water filling at the start of the wash cycle and/or at the start of the rinse cycles.
Check the pressure hose for air leaks and moisture including the air dome. Replace the machine/motor control assembly if no issue is found with the pressure hose and the air dome. Click on the link below for the troubleshooting and repair instruction details.
Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
Jun 17, 2011 | Washing Machines
What does LF means? and what should I do
See the following Whirlpool Service Manual for their Cabrio washer which is basically the same as the Kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
6-1
DIAGNOSTICS & TROUBLESHOOTING
DISPLAY FAULT / ERROR CODES
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
(F30)
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged
the basket but control does not detect a water level change.
• Is water supply connected and turned on?
• Are hose screens plugged?
• Is water entering the tub? If so check pressure hose connection to machine/motor control.
• See TEST #2.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
I have a Kenmore Elite Oasis HE top loader washer; It will start but gives me an LF error.
this is a fault in the water valve control, "LF" means Long fill (fill time exceeeded), so u will need to have the sears guy out to sort this problem out. are the water valves on the wall turned on all the way?
Jul 15, 2009 | Kenmore Washing Machines
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
458 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
