I have a T4053H Samsung HDTV I bought Jan. 2008. My tv is hooked right to cable tv service with no boxes in between. When I press in the numbers it can take up to 6 seconds for the channel to change. The numbers you enter show up on the screen right away & then you just sit & wait till it changes. All my other tvs (older) change as fast as you can press the buttons. Please reply----Thanks
  • butch30 May 01, 2008
    As you suggested I called a TV Technician. He checked for the latest updates and etc. He told me that slow channel changing was normal and there wasn't anything that he could do. It looks like I will have to live with it.
  • 19,396 Answers
It is a fault in the control board or in the remote, try first testing with an universal remote, If it works with Un.Remote change remote, otherwise call repairman
Posted on Apr 29, 2008
How many hdmi cables will i need to hook up my hdtv cable box to tv,stereo,dvd,and a p.c
I really do not know how many HDMI inputs you have on the TV, but that number is the MAXIMUM number of cables you can use.
Jan 22, 2013 | Samsung Televison & Video
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
Samsung hdtv how to know if lightning fried it
If the tv will not turn on it is safe to assume that the electrical storm did damage something in your television.
Jul 11, 2012 | Samsung 46 UN46D6000 LCD TV
Hello. My sumsung HP-T5064 ( bought Jan, 2008 ) after working for few minutes starts clinking and turns off and on by itself. I started doing it few days after cable box has been installed ( wich...
The capacitor is bulging or puffing up more than the other capacitors beside it?Yes,replace it with a new capacitor with the same micro ferit and 5 to 10 higher voltages for a better heat resistance later.This suspicious capacitor is on the power supply board.That the board,where the power a/c cord plug into it.Yes,90-95% that ur tv problems.
Mar 28, 2011 | Samsung HP-T5064 50 in. Plasma HDTV
Picked up used LN-T4053H, hooked it up to cable and I get no signal.
Did you set the ON SCREEN TUNER setup tuner to pick up from the signal from cable?
Did you download the user manul from SAMSUNG web site?
Mar 01, 2011 | Samsung LN-T4053H 40 in. LCD Television
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Nov 09, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Brand new samsung tv. plugged into cable box.
return to seller or take authorized servicer.
Mar 06, 2009 | Samsung 52 in. Flat-Panel LCD HDTV
Just hooked up my new tv to the hdtv cable box and cannot adjust the size of the picture
check the aspect ,format or hd zoom keys on the remotes depending tv model and cable box models.in cable box its the # key under number nine on tvs will say aspect format or size.
Jul 02, 2008 | Samsung Televison & Video
Protron HDTV Cable hook up
if u want true hdtv buy a samsung 1080P LCD
Nov 11, 2007 | Intel VOICE D41JCTLSEURO PFU CT LSGS Comm...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
