Question about Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB HD WITH HUGE 15" TFT SCREEN (GAT93400) PC Notebook
Will not power up
I have a Gateway 9300 laptop but the laptop will not power up even with the ac power supply would like any idea that might help me out to get it working
  • Anonymous Jun 08, 2008
    Battery test is good. Green Light displays on the ac adapter. Does not power up with battery in and by itself, or with ac. No lights on the computer display at all. Noticed yesterday that the laptop was difficult to power on. Took several attempts.
    Is there a fuse or power reset button? This is a second owner computer - no manual.
    I checked with a users group - they said to unplug and remove the adapter, remove the battery, then press and hold the power 'on' for 30 seconds. Then replace the battery and plug in the ac adapter, then power 'on'. No success.
    This source said that it sounds like the motherboard.
If there isn't a light near the power button when you plug in the AC adapter, then you may need a new power button panel, you can buy it on ebay for around $10-$15 if you look around. You have to remove the keyboard first, kind of tricky; there are tabs you have to press down/forward on near the bottom. Then unscrew the middle screw to the power panel and the two screws on either side. Next, just pop it off and remove the ribbon cable by lifting up on the brown latch with a small screwdriver. Just replace the old with the new in reverse order of the disassembly steps.
Posted on Jul 11, 2008
    Scholar:
  • 144 Answers
Do you have any stattus light or even the light like power on light on your laptop ??
Posted on Apr 29, 2008
No a/c power light on laptop
Hello
Well the first thing you should check is the amount of power output to the power supply. for example the computer needs 12V but the AC Adapter only gives 9V.
If that's not it then the actual green light is not receiving that information from the motherboard. that's not an issue if the battery get's filled up and the laptop works normally . If you notice that the laptop tends to shut down quickly when it's not plugged in then the battery is worn out. These things happen since the a laptop battery becomes very inefficient after 2-3 years.
One more thing - try to rotate the input end of the ac adapter cable. maybe it's not making good contact inside the laptop.
Hope this helps.
Feb 02, 2012 | Gateway MT6705 Notebook
Gateway solo 9300 powers up then cuts off
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 22, 2010 | Gateway Solo 9300 Notebook
Laptop will not power up
TRY TO UNPLUG THE BATTERY AND START THE LAPTOP.
Apr 09, 2010 | Gateway MX7315 Notebook
How to open the case of a gateway solo 9300
Hi ,
open the case
(with screws removed). ... Disassembly the Gateway Solo 9300 ...
Jan 17, 2010 | Gateway Solo 9300 Notebook
The ac adapter is not working for my gateway laptop any ideas?
is the green/red light lit? If you have a multimeter check the plug end to see if there is voltage flowing.
Other than that you can purchase a new power pack online through ebay or the Gateway site online.
cost about $45-50
Ple4ase rate my help++++Thanks for using fixya
Nov 17, 2009 | Gateway (1532852) Power Supply
Procedure for removing and reinstalling power jack
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
You also have to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
Oct 13, 2009 | Gateway Computers & Internet
Gateway solo pro 9300 bios password is not remove
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.This is a better way
Dec 15, 2008 | Gateway Solo 9300 Notebook
Gateway solo 9300
Sounds like the cable is not securely connected to the motherboard.
I would doubt the OS is responsible for this problem.
Nice little machine, the service manual is available for download for free. Might give a shot at refastening the cable.
If you're not that enthusiastic about taking a laptop apart, possibly an external mouse?
Put XP back on. If you have enough memory, it runs just fine.
Good luck
Nov 25, 2007 | Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB...
Power Problem
A very common problem with dell laptop's are the "batterys" I suggest calling dell and order a new battery for your labtop.
or
It may be that your psu "power supply unit" may be bad as well.
I hope this solves your problem
Nov 12, 2007 | Dell Inspiron 9300 Notebook
Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB HD WITH HUGE 15" TFT SCREEN (GAT93400) PC Notebook Logo
141 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
