Question about Cell Phones
No Sound on the phone
I have a peculiar problem. There isno sound through the speakers of the phone. If I attach the wired headset that came with the phone, Sound comes through the headset. If I press the speaker ket while the heatset is attached while listening to radio, then there is sound in the speakers. However the earpiece of the phone is still not working. If I make a call, then the mic and the speaker both are not working.
my phone has a setting where i was recording songs and when i tried to play them they and all the ringtones i have don't play, only when the phone is being called.
  • Anonymous May 15, 2008
    same, and this si the second time it happened, this time with my replacement. i noticed that its happened after i fall asleep while listening to the mp3 player through my headphones.
  • phoebebeebee Sep 14, 2008
    My phone was working just fine earlier in the day. I can text, receive calls, and send calls, but I cannot hear anything and no one can hear me talk. I really need my phone to work since I am forever away from home!!
Mine does this periodically too, and it's really frustrating. I've found that it's apparently related to an internal switch in the 3.5 mm audio jack that gets STUCK in the mode as if headphones were plugged in, even when they are not. I've successfully (temporarily) solved it by tapping the phone into my desk to break loose the switch, by re-plugging and unplugging my headphones, or by wiggling them around while plugged in & then unplugging. Hope that helps. It's a design flaw for an otherwise great phone in my opinion.
Posted on Nov 10, 2010
My laptop speakers are not working but there is sound when i attach headset
once cause is that your onboard speaker on your laptop was already been busted, My suggestion is better to use headset or external speaker. Or also try to navigate control panel and go to sound settings then check if their is an option for internal speaker being used. If not then better to use your headset or external speaker. Hope it helps thanks.
Sep 13, 2011 | HP 530 Notebook
Why sound is not coming through the headphone in my c5
try listen thru the wired headset or speakers if still no sound, its the board problem
if have sound, possible of earpiece speaker loose. get it warranty repaired.
Jun 30, 2011 | Nokia C5 Cell Phone
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
Sounds both in head set and speakers
Solution:
i) try somother headset(if you have spare ones...with u), if prob still exists there must problem with sound port(inbuilt sound on your laptop) which is not allowing the wire or chord of your headset to completely plugin to your laptop sound port.....
it is like this  connecting wire is  paritally inside your laptop sound port and partially outside and leading to sounds from both laptop speaker(builtin) and the headset you are connecting.....
Thanking you
M. Sridhar
Dec 26, 2008 | Compaq Presario 700 470024-192 Notebook
Mobile phone Samsung U700. No sound
No sound on the speaker. However, there is sound on headset
Apr 09, 2008 | Cell Phones
Sound stuck on headset
Replace the main speaker in the flip
Jan 28, 2008 | Samsung SCH-a650
It is probably cause by some dirt in the o2 port that causing the switch that detect the headphone to stuck. try cleaning/picking them up using a small toothpick or needle.
Dec 17, 2007 | O2 Xda Atom Exec Smartphone
No sound when calls come in
This problem now seems to be well known issue with this phone, and I too have faced it as an owner of this phone. The peculiar issue being that its not present in all phones and the there is way to identify if the phone will have this problem.
The problem is a software issue, where the phone's speaker gets muted. If you are taking the call, simply changing the volume solves the issue, however the same does not work for incoming calls and you are forced to cut and call back.
Many suggestions have been made on working around the problem but non seems to work. The problem is most common if you select the SILENT profile. Upgrading to the latest firmware 5.11 does not sort the problem, and actually it introduced the problem (as it was in my case).
The best advise i can give is to replace the phone, as it seems Nokia has not managed to fix the issue even after several firmware fixes.
Dec 13, 2007 | Nokia 6120
Low sound in nokia n73me headset
theres some thing wrong with your speakers
because i also have a n73 music edition and the headsets works great
Dec 12, 2007 | Nokia N73 Cellular Phone
No more sound from speaker
I had a similar issue on mine. The easy fix was to insert a headset jack and pull it out quickly. I think something got stuck that turns off the speaker after I put the headset in the jack once. If this is the problem, I think you should also see a headset icon when making calls, even though no headset is attached.
Jun 15, 2007 | Sprint Vision PPC-6700 Smartphone
Cell Phones Logo
289 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
