Question about Microsoft Office Outlook 2003 for PC
2nd PC connected to router no internet connection
We purchased a new set of pc & connected it to a DLink Model DI604 router. After setting up and wiring, the 2nd pc does not have an internet connection yet. What might be the problem. Help would be very much appreciated.
  • 4 Answers
Call your technical maybe it's goog deal.. $20
Posted on Apr 30, 2008
My dlink router model N150 when i connect to my pc zx1945lm4 router ip was not taking my pc
If the internet lights on the router are blinking it's transmitting, it could be the wi fi switch on the lap top is off
Mar 20, 2014 | D-Link Computers & Internet
Using dlink router trying to run my i pod touch but unable to connect to internet
Make sure you have internet connected to the DLink first. You will need a PC to configure the DLink i.e DHCP, SSID, Webkey, etc. Then, you can set your ipod to connect to your DLink.
Feb 13, 2013 | Computers & Internet
Two pc connection by dlink switch
connect the router to the switch using any port-it does not matter which port you use. Connect each computer to any port on the switch-it matters not. The router will assign IP address to the computer as they are added.
DONE!!!
Good Luck
Sep 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
How do i connect dlink dl-524 to pc without i want to set up lapt
You should be able to download the software/driver package as well as manual from the DLink website. Just click on the Support link and lookup the model # of your router. You will need to know which operating system you are running in order to download the correct package. Once downloaded you can install by following the onscreen directions. Hope this helps.
Sep 16, 2009 | Computers & Internet
Linskys wireless-g broadband router not connecting to network
first thing, we need to know what this d-link is... Is this a modem? or another router? Can you check its model #, perhaps at the back? How many ports does it have? To verify your internet connection, try connecting your computer to the dlink and check its IP address (Go to Start> Run> type "cmd". On the black window, type "ipconfig"). Do you have internet connection when your pc is straight to the dlink?
I'm thinking that dlink is conflicting with the linksys settings. If it is, we need to change the IP address of the linksys router. Post back what you find out.
Jun 07, 2009 | Linksys Wireless-G Broadband Router
Hi i hav purchased a Dlink dir 300 router. is this router capable of letting multiple pcs n cell phones connect to it for internet wirelessly with out the need of keeping 1 pc switched on all the time? i...
Yes if you consult the manual that came with the router it will show you how to connect the modem to it and setup the DSL (PPPOE)settings. Some Modems though already have the PPPOE settings within the unit and then the router would just need to be set to automatic. You will need to configure from the PC but afterwards you can shut down all your PC's on the network at anytime.
Jun 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D Link model 2310
When you connected your PC directly to the modem, were you able to get the internet working automatically or did you have to run a dialup-like connection?
If it worked automatically, try this:
1. Connect a PC to a numbered port of the Dlink router (don't connect the modem to the router nor the PC)
2. Open Internet Explorer and enter http://192.168.0.1 on the address bar. This should then ask you to login. (restart the router and the PC if nothing happened then try again)
3. Enter admin for the username and blank for the password
4. Once you're on the Dlink Setup page, click on Network Settings on the left panel.
5. Change the Router IP address to 192.168.2.1 then hit Save Settings
6. Now, connect a cable from the Speedstream modem to the WAN port of the Dlink router then check if your internet is working from the wired PC.
If its still not working, turn off the modem and the router and then power the modem first (wait for the lights to be stable) then plug the router.
Hope this works for you. Goodluck!
Nov 07, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
Microsoft Office Outlook 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
