Question about Creda W100FW Front Load Washer
Creda w/d electrical outlets
I purchased a W/D stacked unit and found that someone had spliced both unit's electrical cords together. I'm trying to find out how to make this safe? Purchase the correct prongs and converter box? Can't find any info!! Help
  • Anonymous Jul 28, 2008
    Hi I just purchased the Creda front load washer and dryer at an estate sale. Afterwards I realized that the three prongs on the outlet plug are like this example -- --- can you tell me where I can find the proper adapter?
    o
You should never splice two appliances togather for obvious reasons. If you are familiar with wiring, my suggestion would be to replace the cord ends your self. You most likely can get what you need at any appliance specific store (smaller store), and you can ask questions to the salesman if you need to and most of these guys have a good knowledge of what to do. But if you are comfortable and you know what the voltages are and the pin configuration to the outlet designated, the ends can be purchased at a Lowes or Home Depot. Hope this helps, and good luck.
Posted on Jul 23, 2008
I have a pnlc1001ya can I get a replacement charging unit as the rabbit has chewed the cord
You want the AC adapter, not the charging unit. If there is sufficient undamaged cord, you can splice both the wires together and use the AC adapter.
Carefully identify the wires - one will have a raised rib or line printed on it. Strip 1/2 inch of insulation off each end of all wires. Matching the wire pairs, twist the stripped wires together. Fold the stripped wire back in line, and wrap the spliced wire connection with electrical tape. Do this for the other wire. Inspect you work to ensure the spliced wires are completely covered and do not touch each other. Wrap the entire spliced section in electrical tape and hook it up to the charging base.
Ebay has a selection of replacement ac chargers. Look on the back of the charging unit for the model number, and observe the voltage and current ratings.
Mar 17, 2015 | Panasonic Lands Phones
I can't recharge my Schumacher PSJ-1812 jump starter. I can't get an extension cord to plug into the outlet on the machine. I think it had a 12V power source adapter unit when I bought it bu
Not unless you can get the pc. back from the person lent it to or make him or her buy a new one or find the one that came with it !
PS. never lend your tools out
Oct 10, 2014 | PSJ-1812 DSR Jump Starter and Portable...
Splicing kirby electric cord
If you are unsure on how to splice the cord back together it may be best to just purchase a new cord. You can find a new G6 cord and it is easily installed into the switch at the base of the Kirby.
Kirby G6 Power Cord
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Kirby Generation 3 Bagged Upright Vacuum
We just purchased a stack unit and the space is confined so during instalation into a cove we will have to stack the units hook them up to electrical water and exhaust and slide them in.How long is the...
I think you have to but them separate from a hardware store. They come in dirrerent lengths. If you purchased one it seems that you would know that by reading the instructions.
Jan 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
My idiot roommate cut my power cord in two and tried to pull it out of the back of the TV. Can I just replace the cord outright? If so, how do I remove the old cord. It won't come free from the TV. dj
You can probably replace the cord outright , but to do that you will have to take the tv apart and also purchase a new cord. If you still have the original cord that got cut, you can just splice it using **** connectors and it will be easier and cheaper. If you do take that route, just make sure you splice the same colors together, and use some electrical tape to re-insulate the cord. Hopefully this helped.
Thanks
Jan 03, 2011 | Toshiba 32A33 32" TV
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Creda 1000 Superspeed, stacked: Motor does not run
Sounds like you have motor problem, I suggest u check the brushes in the motor, most likely cause of problem.
Also check that the belt is still on the motor.
Dec 03, 2008 | Creda W100FW Front Load Washer
Electrical Plug
I guess the washer and dryer are somewhere that someone can get in to use them without permission. Where do you and they get electrical power from?If they are connected through circuit breakers then just throw the breakers when you're not using the machines.
Mar 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
Creda W100FW Front Load Washer Logo
60 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
