Question about Dishwashers
We have big pasta bowls and they do not fit in the bottom section properly.
The top section usually is adjustable - pull the whole upper basket right out (assuming its a front loading type not a drawer) and there should be a second set of wheels. feed those into th track instead. You wont be able to put large glasses etc in the upper tray but should have enough for your bowls...
Posted on Apr 29, 2008
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I have a Haier HDW300SS dishwasher. The top half is cleaning the dishes normally but the bottom dishes aren't being cleaned at all. I've cleaned out the sump and checked the bottom spray arm i
Dear Sir:
See the diagrams attached and proceed according with the common sense.You can use the instruction manual in section troubleshooting.if you do no have go for free download: www. fitness. manualsonline.com or www. retrevo.com
May 07, 2012 | Stoves 27 in. DW60 Built-in Dishwasher
Bottom rack pots and bowls dont get clean
Probably blocked spray arms is the cause of the unit not cleaning properly. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 26, 2010 | Bosch Dishwashers
AEG 250 operating manual
hi friend,
step 1
Remove any large food deposits from the dishes to prevent damaging the dishwasher.
  • Step 2 Load the upper rack of the dishwasher with smaller items, such as glasses, cups and cookware lids. The items must be inserted face down, with the soiled side of each item facing toward the bottom of the dishwasher. Some dishwasher models feature clips, which can be used to secure lightweight items to the tines of the upper rack. The clips work like clothesline pins, and can be moved from one tine to another.
  • Step 3 Load the lower rack of the dishwasher with heavier items, such as plates, bowls and pans. Insert the items between the tines of the rack with the soiled side of each item facing toward the center of the dishwasher.
  • Step 4 Load the silverware basket. The silverware should be inserted into the basket with some items facing up and some facing down to ensure the items do not fit together, which would prevent the dishwasher from being able to clean all surfaces. Knives should be inserted blade down, so they can be inserted and removed from the dishwasher with the handle to avoid injury.
  • Step 5 Add detergent to the dishwasher, and then close the dishwasher's door. Note that the dishwasher has two detergent sections. One dispenser, called the main wash section, has a lid. Open the main wash section's lid by pressing down on the cover latch located next to the section. Fill the main wash section with 3 tbsp. of automatic dishwasher powdered detergent, then close the lid until it snaps into place. The other detergent section is the prewash section. It does not have a lid, because the detergent within the section empties into the dishwasher when the door is closed. Fill the prewash section with 2 tbsp. of automatic dishwasher powdered detergent. Close the dishwasher's door until it clicks into place.
  • Step 6 Prime the dishwasher by turning the kitchen sink's faucet on until it produces hot water. This will ensure the dishwasher has an immediate supply of hot water.
  • Step 7 Start the dishwasher by choosing and pressing the appropriate wash-cycle button, located on the front of the dishwasher's door. Cycle selections include "POTS --N- PANS," "HEAVY" for heavily soiled items, "NORMAL" for standard washing, "CRYSTAL/CHINA" for delicate items, "LOW ENERGY" for lightly soiled items and "RINSE ONLY" for items that will not be washed immediately.
  • hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | AEG Dishwashers
    Dishwasher not completely emptying of water
    YOU PROBABLY HAVE 'BITS' ACCUMALATED IN THE HOSE, WHERE IT JOINS TO THE UNDERSIDE OF YOUR SINK OUTLET.
    SWITCH OFF DISHWASHER, UNDO THE BASE WHERE THE FILTERS ARE AND USE A CUP TO DRAIN OUT THE WATER IN TO A BOWL. THEN CLEAN ALL THE FILTER BITS IN HOT WATER. GO TO THE HOSE JOINING THE SINK TRAP AND UNDO THIS (SCREWDRIVER NEEDED TO UNDO THE BRASS CLIP). UNSCREW THE WHITE PLASTIC END JOINING THE 'U' BEND. LOOK IN THE END OF THE PLASTIC NOZZLE AND YOU SHOULD SEE FOOD DEBRIS IN THE HOSE. CLEAN ALL OF THIS OUT. AND REFIT TO UNDER SIDE OF SINK TRAP, DONT FORGET TO MAKE SURE THE BLACK 'O' RING IS IN PROPERLY. MAKE SURE ALL THE FILTERS ARE IN PLACE INSIDE THE DISHWASHER AND PUT IT ON EMPTY, HOTTEST WASH CYCLE YOU HAVE. PREFERABLY WITH A DISHWASHER CLEANER IN IT. (NORMALLY DEBRIS IS : RICE, PASTA, AND EGG SHELLS, THESE ALL BLOCK THE TUBES AND BUILD UP OVERTIME. FOR SOME REASON THEY DO NOT BREAK DOWN AND PASS THROUGH. BEST THING TO DO IS TO MAKE SURE THE PLATES ETC ARE SCRAPED OFF PROPERLY BEFORE GOING IN THE DISHWASHER. I HAVE DONE THIS MANY TIMES OVER THE YEARS, MAINLY DUE TO THE KIDS BEING LAZY, AND JUST PUTTING THE WHOLE PLATE INCLUDING LEFTOVERS STRAIGHT IN. HOPE THIS HELPS.
    Sep 16, 2009 | Dishwashers
    Garbage disposal...won't drain
    There should be a reset switch on the bottom of the disposal.
    When using a disposal, always run water first, then turn on disposal. Then dispose food. Then keep water running until it all sounds clear before turning it off.
    Mar 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
    Dishwasher discolored
    Cause = Pasta sauce.
    Normally if you run the dishwasher empty (but with proper soap), this can clear it up. Or try running a short cycle with vinegar (about 2 cups) this can also clear it up sometimes.
    Jan 29, 2009 | Dishwashers
    Water fill not working properly
    theres a over flow/check valve in either the left or right corner of the inner tub (looks like a mushroom sotr of,) perhaps this float is getting stuck, or perhaps something has gotten under it i.e. pasta chicken bone.
    Nov 30, 2008 | Kenmore Dishwashers
    Door seal
    generally the notched out section fits around latch hope this helps
    Aug 20, 2008 | Dishwashers
    Dishwashers Logo
    59 people viewed this question
    Top Dishwashers Experts
    Mike Cairns
    Mike Cairns
