Question about Mitsubishi VS-50603 50" Rear Projection Television
Damn TV....why doesn't it turn on when you push the power button??
When the power button is pushed the light will not turn on and you hear a click (only one click), but the screen stays black with no sound. You will also hear a click (just one again) when you push the power button again to turn off. Any suggestions????
  • 927 Answers
Good Day, U-Fix- it;
Try this; CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB.
CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001.
Good Luck, big IRISH.
Posted on Aug 28, 2008
I pushed the on and off button inside the tv set and i can't turn it on
Its a older set--if power light is green does it even attempt for a tiny moment to come on? Also let me know if at turn on you hear a very faint pop or hiss or even a buzz.
May 23, 2012 | Televison & Video
Tv clicks on and off. timmer light stays lite.
This could be a number of things, but first step might be: check that the power button on the TV is not stuck on, there could be a faulty push button or the button is stuck.
Aug 19, 2009 | Samsung HCL4715W 47" Rear Projection...
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
42" Insignia LCD TV will no longer turn on. What is wrong with it?
Do you see any lights on the front when you try and turn it on? and do you hear a clicking sound when you push the power button?
Oct 07, 2008 | Televison & Video
My big screen tv
Those are the two 5amp pico fuses that go out when the convergenec Ics go out on a mitsubishi. You can get the ICs and pico fuses at the following link. If youre not sure which ICs you need leave them a email with your model nuber.Heres the link
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Televison & Video
Won't turn on
I have the same problem; I push the power button green light comes on tv clicks but doesn't come on.
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Off and on switch
Check for burnt capacitor C514 near flyback = 102K / 3KV
Sony part # 1-161-754-00 and open pico fuse in power supply.
Nov 07, 2007 | Sony KP-51WS500 51" Rear Projection...
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
