Question about Actiontec GT704 Router
Ethernet lights When i plug in the ethernet cord to my modem nothing happens but the dsl and internet lights are on
  • 3 more comments
  • jmaf24 Apr 29, 2008
    I have tried another cable and that didn't work either. I'm connecting straight from my computer to the modem.
  • Llora C Nov 16, 2008
    i have the same problem....i went and did what you guys said and reset everything and let everything sync, but my ethernet is still off.
  • Kevin Flannagan
    Kevin Flannagan May 11, 2010
    Have you tried to unplug the modem and let it cycle for about 30 seconds (computer turned off) and then plug it back in and let it power fully up. Then after all lights are blinking turn on the computer. Also, do you have a second computer that you can plug into the modem and verify that the modem is in working condition?
  • Kevin Flannagan
    Also, have you tried another ethernet cable?
  • Jocelyn Viau
    Jocelyn Viau May 11, 2010
    To what other device are your connecting the Ethernet to?
  • 156 Answers
Whenever you plug back and forth between PC and Router and moden make sure you Reset both the router and Modem and give them time to sync.
Posted on May 03, 2008
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I need to know how to hook up a westell versalink ? i dont have directions & i have a dial up connection on my desk top . do i need a server ? i have no idea what to do !!
In order to setup the versalink you need an active DSL account, a phone line cord, a phone jack, a pc or mac, and an ethernet cord or wireless ethernet card. Plug in the phone cord to the phone jack and to the DSL port on the versalink- once the DSL light is solid, plug in the ethernet cord to the computer you have, or enter the wep key on the bottom of the modem into the wireless manager for your system. At that point, if you need further assistance in getting online, contact Verizon or Bell (whichever is your DSL provider)- they can and will walk you through setting up the versalink to connect to the internet.
Oct 03, 2010 | Westell Wirespeed VersaLink...
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Do the dsl modem have to be connected to an isp before the ethernet light comes on. i started service with att and i have a modem westell 6100 i purchased before from them and i still have the software but...
    no. The ethernet light should comes on right away when you plug modem if there is something plug in. There is a but. But if your dsl light is still flashing and not staying solid it is your isp problem.
    Oct 25, 2009 | Westell Wirespeed LiteLine 6100...
    Ethernet light went off and won't come back on on dsl modem
    no matter what the model is, the thing has to work. it is not that ur new modem is smaller so it is not working . Check the suggestable router modems for AT&T . if ur modem is working fine , then install the modem drivers in your Pc.
    Aug 21, 2009 | Computers & Internet
    Ethernet won't reconise modem for xbox live
    Once you have everything hooked up:
    Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
    Unplug the power cord on the modem and plug it back in- once all the lights come back on
    Unplug power cord on router and plug it back in-
    Hope this helps.
    Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
    D-link dsl 320b lan light
    Maybe it is ethernet driver
    Apr 23, 2017 | D-Link DSL-2320B
    I have no computer or cable and need to set up internet on my PS3
    ??? A router will NOT replace your modem; the router won't work without the modem. If you're going to give advice, please make sure it is somewhat correct.
    Okay. So first you need the telephone cord to go from the phone jack into the DSL port on your modem. Then you need the Ethernet cable that came with your modem (looks like a phone cord but much bigger) to go from the ethernet port in the back of the modem into the wan or internet port on the router. Verify that the DSL and internet lights are on on the modem.
    For the rest of the setup, watch this . It will walk you step by step in connecting your PS3 to the wireless internet. Thanks and please take a moment to rate as fixya.
    Feb 04, 2009 | Sony Playstation 3 (PS3) Console
    Actiontec GT704 Router Logo
    376 people viewed this question
    Top Actiontec Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
