Question about Archos AV400 Digital Media Player
Could you please replace the battery for my archos av400, and at what price
    New Friend:
  • 34 Answers
Http://www.lacc.com/product.asp?pf_id=PMPARAV400
Found a battery here for 66.00.
Internet is so helpful, all you do is punch in your model number, or what you would like to do.
Posted on Aug 11, 2010
SOURCE:
I cannot accesss my archos av400 20GB via usb. I tried different cables. If I select Hard drive, windows dont detect my archos at all but when I select windows device, my windows detect the archos but not...
Your windows is installed on FAT 32 partition, so it is not recognized partitions bigger than 4 Gb. Change to NTFS. ATTENTION ! All informations on your computer will be lost. Do this only after saving your private files !!!
Sep 11, 2017 | Archos AV400 Digital Media Player
No Audio on Video Clips from AV400 playing on Laptop Win Med Plyr
is very likely what is your turn to review programs carefully mind because that is a bad configuration
Aug 22, 2009 | Archos AV400 Digital Media Player
I cannot play MP4 on the Archos AV400 player. It
Meny people have had this problem. Try making sure that the format on the vid is MP4
Jul 13, 2009 | Archos AV400 Digital Media Player
What kinda of charger can i use for an archos av400 can i get one at radioshack?
Hi I have the 605wifi so would think they are the same, it says
5volts dc the attatched plug (cylindrical) has + pos inside,
-neg is on the outside.
I would also make sure its a regulated output.
Hope this helps
Dec 12, 2008 | Archos AV400 Digital Media Player
Archos AV400 Power Adapter
wallwart is model # trc-05-1600 made by group west I have one, though I cant let it go... BUT may battery is dead and i have to unscrew? the back to replace it. Got any tips for me?
Sep 30, 2008 | Archos AV400 Digital Media Player
AV480 battery replacement
Some AV400 models are made with integrated batteries which
are designed to last for the life of the AV400. This means that you will
not have to change them. If, in the exceptional case, the batteries need
changing, this should only be done by an Archos technician.
If your player is dead, it is probably NOT the battery that's the problem.
Jun 07, 2008 | Archos Audio Players & Recorders
I have a archos av400 and it is coming on read access error can't read from hard drive please help
If it is a av400 series
plug it into the computer and attempt to format it.
If it fails its a very high probability the hard drive has failed.
there is a slight possibility its the ribbon cable that connects the drive to the main board or the controller in the archos so I would check the drive after removal and prior to buying a new one.
this can be done in a usb caddy or with a 3.5" to 2.5" converter (about $5 on ebay) letting you put the drive in a PC for testing.
If its above 40gb any 2.5" laptop drive upto 100gb can be fitted.
If its a 20gb you need a single platter 1.8" ata drive
any further questions just ask
Apr 27, 2008 | Archos AV400 Digital Media Player
It won't start. my Archos AV400
Probably a bad connection from the drop, or one of the ribbons has gotten loose. The only way to tell, is to open up the player and examine it and look for damage.
Sep 05, 2007 | Archos AV400 Digital Media Player
Archos
This is a hardware problem, and it might be a ribbon cable that has come loose or cracked. Also, the backlight might be the problem. The av400 series was the same lcd as the av300 series and can be found at www.hotmp3technology.com. Haven't found any other place that stocks lcds.
Nov 13, 2006 | Archos AV400 Digital Media Player
Archos AV400 Digital Media Player Logo
137 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
