The beeping is trying to let you know that there is a hardware problem. it is posible that maybe one of your fans has failed and when it reaches its maximum heat limit it shutsdown. Look through your manual. also on the back you shoul have a set of 4 lights. they should all be green. if one or more turns yellow in your manual it will explain wha the error code is. I beleive that its also availabel online at dell.com
Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Also open back cover of cpu then reconnect the RAM memory and both connection to harddrive make sure motherboard is not ground with cabinet.Then check. Let me know if you need further assistance. Thanks for using FixYa.
