Question about GE 24 in. GSD2000Z Built-in Dishwasher
Pump comes on but no water comes in
Greetings! I have a GE Potscrubber (not sure what model exactly) dishwasher that was working fine until a few days ago. No water comes in, even though you can hear the pump whirring. I checked the drain hose for clogs. I can feel air coming up from the sprayer arm/tubes when the pump is on if I put my hand right above it while holding the door switch in. Any ideas? I'm pretty handy with electrical stuff so I can test items if somebody can point me in the right direction. Here are a couple of pictures:
Thanks!
-bill rowell
  • ZenPddlJmpr Apr 30, 2008
    Actually it was the timer that was bad. We had a repairman come out and fixed it today. He also suggested we bump up our hot water temperature to better clean the dishes.
  • marty18 Nov 20, 2008
    You can hear the rotation of the arms spinning, but no water is coming through
    Genius:
  • 1,073 Answers
Check the water inlet valve for proper voltage if you have voltage the water inlet valve is bad
Posted on Apr 30, 2008
I live in Brazil where the city turns off the water every few days. So everyone uses a water tank on the roof to store water. Thus, there isn't much water pressure at the faucett. I have a GE Potscrubber...
the solenoid just opens and closes the tap and is rated only for a max pressure of 40 psi
and higher and it will not shut off properly
your fix for this problem will be a small pressure controlled pump connected before the water to the washer so that when the washer requires water the drop in preset line pressure will activate the pump and produce pressure up to the 40 psi
when the washer shuts of the water requirement, the pump stops operation until the next water requirement cycle
such units are used in RV units , caravans , homes using tank water supply and can be obtained from irrigation and pump shops , or caravan places and some marine boat shops as the same units are used on board
May 27, 2017 | General Electric Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
When the water drains at the end of the cycle, water drains from the bottoom of the dishwasher, around what looks like an actuator arm? not exactly what the model # is all i know is it is a GE potscrubber...
Hi, I have seen this a lot when I did maintenance work for apartment communities.The part to fix this depending on modle was $85-$125 six years ago, I would just replace it.
Mar 05, 2011 | GE Dishwashers
When I turn on the GE PotScrubber dishwasher with water, water is leaking out from disher please advise. According from one repair guy, it is related to pump issue please adivse
first try to look and see where the water is coming from,,,the bottom of the unit,,,,or the front of the unit...remember the door has a seal all the way around it and it has to seal correct and make sure the latch is all the way in lock postion
Feb 19, 2011 | Maytag Dishwasher
Potscrubber 900 Dishwasher won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Aug 27, 2009 | Dishwashers
GE Potscrubber 800 Leaks
See if your parts store can mic the oring and match it to one
May 01, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwasher not washing
sounds like the wash pump (wich recirculates the water during wash) has something stuck in the impelor or the wash pump motor is faulty. someone qualified would have to check this for you
Feb 18, 2008 | Dishwashers
GE 24 in. GSD2000Z Built-in Dishwasher Logo
251 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
