Question about Samsung RS2534 Side by Side Refrigerator
Frigadare standup freezer
I left the freezer door cracked, by accident from Friday evening until discovered today Monday. The inside is still cold, but not frozen. Shut the door hours ago and not freezing. What can I do? Did I break it? My husband is going to be do mad!
  • 828 Answers
May require a complete defrost before it is returned to normal operation.
Posted on May 06, 2008
I purchased a brand new Frigidaire refrigerator this month (December) and for the past couple of weeks the ice dispenser and water dispenser were working just fine until today. The ice maker stopped...
Hi and welcome to FixYa, I am Kelly.
Your Refrigerator is still under the manufacturers warranty so there is little you can do before contacting customer service. Having said that; there is something you can do before calling for service. I suspect that just maybe your freezer is too cold and the plumbing for the comparement and door water supply may have frozen. Empty the freezer and place a fan blowing into the freezer compartment for over 2 hours. It makes a water mess so be prepaired for the necessary tending to the drips. After the over 2 hours of manual defrosting with a fan check the water in the door function to see if you have water flow. If you have flow at this time you need to begin raising the freezer temperature until you no longer experience water line freeze ups. If after the manual defrosting period you still have the problem you will need to call for warranty service.
One other thing to check is to depress the door light switch and make sure the light is going off when the door is closed. Even if you discover that the light is staying on with the door switch plunger depressed you must contact the Frigidaire service team for warranty service. Since you did not provide a model number there is a possibility that your light switch is actually located in the upper door hinge area. The number for warranty service is listed below.
To reach a service team member, please call:
1-800-374-4432
Monday-Friday, 9:00am-5:30pm (EST)
There are many things I could have you do but all of them would void your warranty.
Thanks for choosing FixYa,
Kelly
Dec 30, 2010 | Frigidaire Refrigerators
Cracked screen on my navman my55
I would contact navman via their website, usually dont cover physical damage but it is worth a shot.
Maybe tell em it cracked in cold weather?
+1 714 204 3389
Service hours are 10AM - 3PM (CST), Monday thru Friday.
Regards,
Rylan
Dec 15, 2010 | GPS
Freezer door was left open, now after one day freezer is not cold
you can unplug it and let it defrost on it's own or you can melt out the air ducts,you'll have to shut down the freezer,remove the shelves and remove the inside back wall of the freezer section and melt out all the ice in the right hand corner and any ice on the coil.when melting out the air ducts be careful not to damage any of the plastic or styrofoam on or inside the wall,heat up the area with a hair dryer for a couple of minutes and then move to the coil,after a minute or two go back the the air duct,when you think it's melted out enough turn the freezer back on and with your hand check to make sure the air is blowing into the fridge side,if you can feel air blowing then your all set,if there's any ice left in there the defrost will take care of it.if you have another fridge to put your food in or if the food can't be refrozen i'd just unplug it and let it melt out on it's own over night and you can clean it out while everything is out of it.let me know how you make out and good luck,hope you didn't loose that much food
Jun 06, 2010 | GE GSS25SGMBS Side by Side Refrigerator
We have a Roper by Whirlpool RT21LMXKQ freezer on top. Friday night it started clicking and the compressor would come on but only run for a millisecond before it cut off. Satruday morning we left if off...
It sounds like a start relay problem. try and see if you can remove the start relay and purchase a new one. You may find that you have a capacitor start & run, it could also be the start/run capacitor failing. at least the compressor is working, so all evidence leads to start relay failure or start/run capacitor failure. Try these first they are cheap enough to buy. if you are not sure you can check this yourself get a local sparky to look at it.
May 17, 2010 | Refrigerators
I`v got an american whirlpool fridge/,somehow the freezer door was left open (not sure for how long),but when discovered lights inside were flashing/clicking.the water dispenser/temperate control on the...
A serious problem You have to take assistance from a technician. Due to overload as the door was left opened either the compressor motor or the condenser is burnt out. Please have it checked up. You will not be able to repair it yourself as it may require replacing parts.
May 02, 2010 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
I have cracks on the face plate of my Garmin GPS 60CSx
Ouch. This is one of Garmin's better handheld GPSr units. The device is weatherproof (maybe even waterproof, too - I forget), but since the case has been compromised that is no longer the case. Superglue may work, but it may also cause more problems due to smudging while still wet - and if the glue "melts" the plastic. I'd contact Garmin Customer Support below and see if they have a better remedy.
North America - Consumer Products (for all Garmin products except Apollo aircraft)
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
E-mail Product Support
Europe - Consumer Products (for all Garmin products except Apollo Databases)
Austria For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 43 (0) 3133 3181 0
Website
Belgium For all Garmin products except Aviation.
Friday: 9:00 AM – 15:00 PM (GMT/UTC +2)
Phone: 00 32 2672 5254
Website
Denmark For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM Central European Time (GMT/UTC +1)
Phone: 00 45 4810 5050
Website
Finland For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 16:00 PM (GMT/UTC +3)
Phone: 00 358 19 311 001
Website
France For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 33 1 5517 81 89
Website
Germany For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 17:00 PM Central European Time (UTC/GMT +1)
Phone: 00 49 898 58364 880
Website
Italy For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 13:00 PM / 14:00 PM – 17:30 PM (GMT/UTC +2)
Friday: 9:00 AM – 13:00 PM / 14:00 PM – 16:30 PM (GMT/UTC +2)
Phone: 00 39 02 3669 9699
Website
Portugal For all Garmin products except Aviation.
Monday – Friday: 09:00 AM – 12:30 PM / 14:00 PM – 18:00 PM (GMT/UTC or GMT/UTC +1 depending on city)
Phone: 00 35 1214 447 460
Website
Spain For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 13:30 p.m / 14:30 PM - 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 34 934 972 373
Website
Sweden For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 00 46 7744 52020
Website
United Kingdom For all of United Kingdom users and customers in unlisted countries in Europe, Africa and Middle East
Monday – Friday: 8:30 AM – 17:30 PM Western European Time (GMT/UTC)
Phone: 00 44 808 238 0000
Website
Sep 28, 2009 | Garmin GPSMAP 60CS GPS Receiver
LG French Door Refrigerator 3 door - Smoke out of Door Panel
Take out the freezer bins and look at the very rear of the freezer compartment. This is where your ice maker fan is. If it is caked with ice you have to defrost it. It's a pain, but it fixed my problem.
Mar 15, 2017 | LG LFC21760 Bottom Freezer French Door...
We left the freezer door open all night by accident two days ago
I turned the fridge side off on mine, and left it overnight (last night!). This morning there is frozen stuff in the freezer. I think the compressor motor just needed ALOT of time to cool down b4 it would work properly again
Jan 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
99 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
