Question about Dryers
How do you put the belt on a 1996 dryer belt? The pulley had fallen to the bottom of the dryer and now we are unsure of where it is originally supposed to be.
  • 172 Answers
Hi 815carey,
That is a hard thing to describe with out a diagram but I will try my best for you. First thing would be to put the belt around the motor. then take the idler pulley and pull it back and put it under both parts of the belt. This will supply the tension you need to keep the belt tight. If you are having trouble getting the the pulley inplace I would need to know the brand of dryer. In most cases if it fell off it is a whirlpool or a whirlpool made Kenmore. It that case the idler will mount directly underneath the shaft of the dryer just slightly to the left of the pulley on the motor. I really hope this helped you. mca0824
Posted on May 02, 2008
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
Looking for diagram to put belt back on barrel in the maytag centennial. pulley has fallen to bottom and do not know where it goes back to. maytag centennial commercial dryer medc400
Copy and paste this Factory Service manual for the Centennial dryer.
It has all your answers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/79aaf530992e93a0852572c3006587ed/$FILE/8178629.pdf
Sep 06, 2010 | Dryers
Changing the belt
goes around idler pulley and motor. idler pulley fits into slots on bottom of dryer and the belt tension holds it in place. looking at it from the front and going clockwise the belt goes around the drum and then around the motor pulley and thru the idler pulley. in fact if you put the bottom loop of the belt thru the pulley from the left you then loop it around the motor pulley.
Jun 26, 2010 | Estate TEDX640JQ Electric Dryer
What is small blue plastic wheel?
The small blue wheel, just next to the Motor, is the tension pulley, your belt should go around it, before going around Drum
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Drum won't turn
Your dryer uses a belt wound around a spring loaded pulley and, around the middle of the drum and, around the motor pulley to turn the drum. If you feel capable of fixing ths yourself: Unplug the dryer, if it is gas or, electric. if it is gas: shut off the gas line to the dryer then remove the gasline; next pull the dryer out from the wall and, remove the back panel. Once you do this you will see that the belt has fallen off both the motor pulley and, the spring tension pulley. put the belt back on so that the belt is tight around the drum and, the drum will turn again.
Apr 05, 2010 | Whirlpool LER4634J Electric Dryer
How to reinstall Idler Pulley and belt for kenmore Dryer Model 110.66112501
First, assuming you have the drum out, there are two slots on the bottom plate of the dryer, hook the end of the idler pulley into the left slot with the angle as you look at it up and to the left. as you set the pulley in place the second slot will match the prongs of the idler pulley. With the idler in place, now put your belt around the drum (you should see a polished spot where the original belt rode and wore off the paint). Then use the belt to help guide the drum install. Set the drum on the rollers in back, keeping the drum level to the dryer. It helps if the whole dryer is tipped back against a wall at about a 45 degree angle to get the drum in place, but that makes your aligning the belt a pain at the same time. I suggest have the dryer at an angle to put the drum in then place it level to align the belt.
You'll need to use both hands to get the belt in place. First thread the belt under the idler pulley wheel in the opening under it. Next you'll need to push the idler wheel as far up and to the right as you can to get the tension all the way off as you hook the belt around the motor. Once on the motor, slowly let the idler down into place.
If everything is aligned correctly it will work just fine. Just make sure when you put the bulkhead in again that the drum rides on top of the slider pads and that the drum rotates freely with only the motor tension on it. 839edf2.jpge839dbf.jpg
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Frigidaire dryer tub will not turn
It sounds as thou the dryer drive belt has either broke or slipped off the motor drive pulley.
To determine which is the case, you'll need to unplug the dryer from the wall outlet (safety first!) OR turn off the gas valve too. Now pull out the dryer so you can remove the rear service access panel at the bottom of the dryer. Once you've removed the access panel, get down and look into the dryer with a flashlight and see if you can see the electric motor. Now see if you can see the drive belt around the motor pulley, or if the belt is broken and has fallen into this compartment.
If the belt is not on the pulley, grab hold of it and see if you can spin/rotate it around the drum, if you can do this all the way around, the belt is likely still good (check for damage as you slide the belt around).
You should be able to get the belt onto one side of the pulley and with your hand, carefully rotate the motor drive pulley to get the belt back on the drive pulley.
If the belt is broken, you'll need to install a new drive belt, which will take some further instructions to perform and will be made eaisier if you can provide the full model number for your dryer.
Hope you find this Very Helpful and best regards!
Aug 18, 2009 | Frigidaire Dryers
Installing the belt around the dryer drum and pulleys. I have a broken belt and a loose pulley at the bottom of the dryer. How to I get the pulley on? Where does the pulley attach to create the proper...
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Phil
Apr 14, 2009 | Dryers
Whirlpool dryer heats but the drum doesn't rotate
There is usually a large belt that goes around the drum to turn it ...it is either fallen off the motor pulley , broke .....or the motor may be gone in it ....not sure if there are any fuses for the motor on your dryer .
If you can tip the dryer over the bottom is usually open and you can see the motor and belt from there
Jan 09, 2009 | Kenmore 64952 Electric Dryer
LER6636PW0 drum does not turn
hi fakestar,
here is an exploded view of the dyer, and you can see where the pulley came off.8dd05ba.gifpart number 24 are the pulleys.
another picture is for the belt and the tensioner
1e696ba.gifpart number 53 is the tensioner and part number 56 is the belt.
it just tricky on how to put the belt.
first put the pulley back to its location then slowly insert the drum to the dryer while putting the belt around the drum with the grouve of the belt facing the drum.
have a helper hold unto the drum , in place, then lean underneath towards the motor and put the tensioner to its slot at the flooring, just like in the drawing, then insert part of the belt under the pulley of the tensioner then with your left hand, hold the tensioner pulley and with your right hand, grab the belt which you inserted under the pulley, and bend the tensioner towards the right with your left hand while the right hand is pulling the belt towards the motor until the belt loops to the motor's pulley.
i hope i was able to explain that one.
that is really tricky to put on.
tnx 4 using fixya,
drcool
Oct 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
