Question about Bang and Olufsen Beosound 4000 Shelf System
Bang and olufsen stereo repair
My stereo by B & O is not reading when a cd is loaded to be able to play it
  • 1 more comment
  • Anonymous May 11, 2008
    the cd player is not spinning everything else works fine.Thank you
  • Anonymous Jul 07, 2008
    same thing repace lazer once and now somethin eles cost lots
  • robin1312 Jan 24, 2009
    I have the same problem. Everything else works, except the CD player!!!
Your best bet for this is to contact you local B&O and have it professionally repaired. These units are tricky to work with, and not everyone is capable. For more info refer to a search for the sterophile's sites.
Posted on Aug 26, 2008
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
Aug 19, 2014 | Bang and Olufsen Beosound 2000 Shelf...
Problem playing CD's
beosound 9000? have you moved the unit.this unit requires cd mech suspension adjustment depending on how it is placed,eg. vert. flat horizontal.check handbook and adjust as required.if it has not been moved then workshop repair needed
May 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
On our Bang and Olufsen Beocenter 9000,
if sticking is only your issues, then replace all belts. Cleaning has nothing to do with the sticking of doors.
Apr 06, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Feb 15, 2009 | Audio Players & Recorders
Owners manual
Below are links to the manuals. I also have this system with the original manuals.
Basically, press the "load" button to open up the CD mechanism, put a CD on the spindle, and press load again to close the CD mechanism. Press the "CD" button to start playing the CD. Page 12 in the User's Guide has instructions on configuring the radio presets.
http://www.beocollectors.com/usermanuals/beosound4000.zip
http://www.beocollectors.com/usermanuals/beosound4000guide_en.zip
Dec 18, 2008 | Bang and Olufsen Beosound 4000 Shelf...
18 year old Beocenter 9300 CD won't play most CDs
cd unit unable to read disc,replace or try cleaning laser lens.cd clamper may be misaligned or faulty,check operation in service position(top up).
Dec 18, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
B & O CD Player
optical pick-up assy discontinued.this is not always the cause of not reading.try replacing 30tr6108(bc338) and 30c2103(33uf 16v)
Dec 29, 2007 | Bang and Olufsen Beosound 2000 Shelf...
Sounds like the belt drive that controls the doors is broken. If you're a repair headed person, you can get the repair manual online for $25 or so. Parts may be harder to get, but with the proper imformation, you may be able to do the work yourself.  It's both tricky and super easy because the design is generally very very good, but knowing the technical details requires a decent amount of patient brain work and proper tools.  DaveA
Dec 02, 2007 | Bang and Olufsen Beosound 4000 Shelf...
MY beocenter 2 does not recognise any disk
I have blue lines across my Beovision 3 TV screen
Nov 04, 2006 | Bang and Olufsen Beosound 4000 Shelf...
1,386 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
