Question about Memorex MMP8565 MP3 Player
Stop responding or disconnected
My daughter has an MP3 player and all of a sudden when you plug it into the computer no files show, and when you try to add songs it says "program either stopped responding or has been disconnected". We have tried it on several songs and it says the same thing. The songs are still on the MP3 because she can still play them but when plugged into the computer none show up and we cant add or delete songs..... Can anyone shed any light????
If so PLEASE email me at my_give_a_damnn_is_busted@yahoo.com
because this is getting very aggravating, and honestly dont know how I got to this message board so probably wont be able to get back to it if you post a response here......
Thanks in advance
  • booman4 May 03, 2008
    my player froze on me how do i manually reset it
  • 8,596 Answers
1) Format the player first - instructions are in the user manual
2) Upgrade the firmware
If you cannot do any of the above due to non-PC-recognition:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 23, 2008
I have a svp mp300 media box. When i plug the device into the computer i bring up the mp3 file and copy and paste the music and it shows as being in that file. however when i disconnect the device and go...
I had the same problem and finally figured out that the music was going to the device, but it was not under the mp3 file. If you go to 'computer', then click on the drive you have it plugged into you can drag the files into the mp3 file.
Dec 25, 2009 | Audio Players & Recorders
Music will not play
I managed to get this sorted by changing the default setting in windows media player from ripping the CDs as a wma protected file to a mp3 file.
Dec 25, 2008 | Mattel Barbie Girls MP3 Player
Sync problems
try to use the utility that comes with ur device.
Dec 19, 2008 | Sylvania Dual Deck DVD/CD/MP3 Player
"Not enough space for music DB. Please free 90MB"
What has happened is that when you connected the device to the computer if automatically downloaded everything on your media files thus filling up your MP3 player
You need to go in and delete the files you do not want. click the bottom part of the disk or dial and it will show a menu to delete FIRST,
you must let the battery run down(disconnect the cable and when the battery has discharged, you can plug it back in to recharge, then you can work with it to delete some of those files that are overloading you device This happened to me and this was the only way to unlock it when it locked up
Oct 29, 2008 | SanDisk Sansa Fuze MP3 Player
Ilo mp3 player
Reset it , restart your computer, and try again
Apr 23, 2008 | iLO (2 GB) MP3 Player
Dead MP3 Player?
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Nov 13, 2007 | MyMusix PD-6030 MP3 Player
Phillips GoGear 4Gb - Can't sync songs onto player...
This is only a makeshift solution.
I use a philips gogear sa52xx and found out, that deleting the drivers, then reconnecting the Player and pressing F5 in the explorer allows me to normally access the philips gogear sa52xx for about 30 seconds. After that, out of nowhere the drivers will sever and the Code 10 error appears. So, another disconnect - deinstall of the driver - reconnect - F5 in the explorer until the Player appears and then sync. The proplem is, that this works best (maybe only) with mp3 files...
So convert your music files into mp3 first, than do above steps for drag 'n' drop.
Usually, you need to do the whole procedure 2 times for a CD, sometimes 3.
Oct 31, 2007 | Philips GoGear SA178 MP3 Player
Need to solve this problem!!
You need to Get a Bigger Memory ,512mb is not very Large Radio Shack is selling Memory 1 gig for $19.95 ttech
Jul 19, 2007 | SanDisk Sansa m230 MP3 Player
Error when trying to copy files to or delete files from ilo 1gb mp3 player
The Walmart/Asda mp3 players in the uk have the same problem, I have the formatting software on the cdrom that came with it and it doesn't work 'Surprise'. The problem normally happens when you try to either upload mp3's more than one at a time or delete all at the same time causing a file the folder to become corrupt and stop everything. Is there possibly a factory reset menu on the player, if not you will have to search the internet for your manufacturer to see if they have an on-line formating tool.
Jan 13, 2007 | iLO MP3 Player
Mp3 player wont upload songs!!!
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 02, 2006 | Philips HDD1630 MP3 Player
Memorex MMP8565 MP3 Player Logo
73 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
