Question about Samsung SMH7174BC Microwave Oven
Lights flash and crazy display
After 5 to 10 seconds of use, the lights flash on and off. The display flashes funny (*#@%etc) symbols, unit stops working, and gfi outlet on opposite wall blows.
  • Nanatutu May 29, 2008
    My problem is very similar. After a few seconds, the lights flash with crazy symbols, ove stops working. Display goes to 0 eventually.
    I have tried unplugging for 10 seconds or more...still doesn't work.
  • Samsung Master
  • 9,098 Answers
(If yours is not a Samsung, please reply back with your brand and model!)
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may even send you a replacement magnetron.
You can order Samsung parts here. You can find your nearest Samsung-authorized service center here.
Posted on Sep 06, 2008
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
We have an Amana AMC6138AAS microwave/convection oven. I was cooking popcorn last night and opened the door before the timer stopped. When I opened the door the inside light and the control panel went...
Did you have a power failure? Could be an overheat situation. Try unplugging the unit, wait 30 seconds and plug it in again. This resets the unit as long as there isn't a breaker or fuse blown. If it is a power issue, the display should start flashing. Did you get any error codes?
Dec 20, 2017 | Amana Microwave Ovens
When machine is first turned on it will run till bin is filled and it cuts off, but will not restart after ice is removed from the bin.This os a hoshizaki commercial ice machine
Remove front panel, look at controler,(where the blinking lights are) there should be a sticker on the back of the panel that tells you what the problem is by how the light flashes. IE- if light flashes 2 times, stps, flashes 2 times,etc, etc
Oct 08, 2010 | Microwave Ovens
Not working
It sounds like 2 separate problems:
1) One of the cooktop lights may have shorted. Sometimes this happens and causes damage (repairable) to the control circuit board. Sometimes it will result in the lights or fan not working, or not turning on.
2) You may have a bad magnetron. See this FixYa solution.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | GE Microwave Ovens
Microwave not heating
The diode is bad, no doubt about it. In most cases replacing the diode should solve the problem.
Sep 01, 2009 | Microwave Ovens
Doesn't heat anything
HI, there is only one in-line fuse link that is designated for the power board. this is concerning the Magnetron. this heating device has failed. replacing the Magnetron will fix this issue.
Jun 17, 2009 | Emerson Black Microwave Oven
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Microwave Ovens Logo
135 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
