Question about Mitsubishi VS-6043 60" Rear Projection Television
No picture just sound
My television was working fine then one day the picture went out, a blue line appeared in the middle of the screen then thescreen was blank. I turned it off then after a while turned it back on and the picture worked again. It started doing this more frequently now & it takes longer for the picture to come back on. The sound & everything else seems to work fine when this happens. Any ideas?
    Problem Solver:
  • 26 Answers
Your projection tubes are messed up. It's a very expensive fix, just get a working TV off craigslist with a smashed screen and reuse your screen itself (usually 100-200$) or just toss the TV and upgrade to an LCD
Posted on May 28, 2008
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Picture stretching with Red, Green, and Blue Image Overlays
assuming that you have adjusted the convergence and this had no effect. you might have some blown convergence chips and/or resistors. these make the 3 color line up with each other.. my 55 in phillips did the same thing and the more i used it the worst it got. first it was the blue and the red and finally the green., replaced chips and resistors and the problem went away... good luck.. a lot of soldering involved. but the chips are only like 11.00 each and the resistors are like ten for all three.
May 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
No picture, no sound
the power supply for the convergence circuit is not working, check for open resistor on the primary
Nov 24, 2008 | RCA P52926 52" Rear Projection Television
Toshiba 50H72 Rear Projection Television
You will need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link and they will provide free instalation instructions with pics and also free on line tech support so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Toshiba 50H82 50" Rear Projection...
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Red, blue and green vertical lines in middle of screen all functions are ok
tibs?? what are tubs?? Your problem is a convergence problem. there are two stk###-### you have to have a TV repair person relace for you . there may be some touch up alighnment needed also when IC's are replaced. Good Luck
Aug 14, 2006 | RCA P52960 52" Rear Projection Television
Televison & Video Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
