Question about Concept DDM-200 Car DVD Player
Touch screen the touch screen on my ddm-200 seems to be out of wack.. i have to touch approx 2,3 inches away from the spot i should touch to change the stations and settings thank you for a reply Tom
    Genius:
  • 3,587 Answers
That's really offset..will need to be recalibrated..this one under warranty
Posted on Apr 29, 2008
What is the gap on the coil in a sthil fs38 weed wacker
W H a c k e r not wacker
wack
wak/ USinformal
adjective
adjective: wack
1.bad; inferior.
"a wack radio station"noun
noun: wack; plural noun: wacks
1.a crazy or eccentric person.2.worthless or stuupid ideas, work, or talk; rubbish.
"this track is a load of wack"Origin
1930s: probably a back-formation from wacky.
whack
(h)wak/ informal
verb
verb: whack; 3rd person present: whacks; past tense: whacked; past participle: whacked; gerund or present participle: whacking
1.strike forcefully with a sharp blow.
"his attacker whacked him on the head"North Americanmurder.
"he was whacked while sitting in his car"noun
noun: whack; plural noun: whacks
1.a sharp or resounding blow.2.a try or attempt.
"we decided to take a whack at spotting the decade's trends"3.British
a specified share of or contribution to something.
"motorists pay a fair whack for the use of the roads through taxes"Origin English thwack
Jul 19, 2016 | whipper snipper stihl fs 38
I have a problem with our Sony Bravia 32" inch..
It may be due to voltage variation.
TAKE IT TO A SONY DEALER AND ASK FOR REPAIR.
Aug 21, 2013 | Televison & Video
The touch screen is not responding to any of the touches and it started as if the screen alignment was not correct like if you want to dial a number and you are pressing 8 it will write 2 but now it is nor...
i have a nokia x3-02 the touch screen seems to be out by approx 1/2 inch i.e. pressing messages gets camera, due to this fault i cannot alliange it , can suggestions
Jun 29, 2010 | Cell Phones
Screen allignment hp ipaq hx2410 pocket pc
Try Realigning the Touch Screen
1. Tap Start > Settings > System tab > Screen.
2. Tap Align Screen and follow the instructions.
Mar 18, 2009 | HP iPAQ hx2410 Pocket PC
White oval spot in center of screen on garmin 2720 gps
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
If the touch screen is still working the moisture probably isn't between the layers. My guess is moisture got through one of the gaskets and made it's way in between the touch screen assembly and the TFT display.
If you want to clean it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the ones by the IR receiver.
Now that the touch screen is in your hand you can carefully clean the moisture from between the two assemblies. The gaskets are tricky to install again but it can be done, maybe you'll see where they were leaking.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Spotting on IBM R40 TFT Screen
you can get a screen replacement cheaply on ebay/craigslist
Aug 31, 2008 | IBM 11P836402 for ThinkPad R40 Monitor
Samsung HP-T5043 blank/black square in center of display
turn off the closed captioning. it is set to a text mode which only certain stations use with their closed captioning. use the tv remote menu key and find closed captions and turn it off
Apr 13, 2008 | Samsung HP-T5044 50 in. Plasma TV
Frozen touch screen
I have the same problem essentially. The only thing I can do is pan left and right in map mode. I can't access any of the buttons that appear onscreen as the touch screens calibration (or something) seems wacked out. The only time the unit functions even remotely normal is if its *VERY* hot. Almost too hot to touch. Anyone have a solution?
Apr 09, 2008 | Lowrance Iway 500c GPS Receiver
P990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
A magnet touched my screen
My son touched my television screen with a magnet in two spots leaving two discolored areas on the screen,purple and green in hue. I read many quick solutions to this problem on the net and none seemed to work completely,so what i did is took the same magnet that touched the screen and held it in my fist,then with TV on i waved my fist all around the screen working from the spots outward to the edges and this worked completely! Hope this helps someone..
Apr 04, 2006 | Sanyo DS27800 27" TV
Concept DDM-200 Car DVD Player Logo
64 people viewed this question
Top Concept Car Audio & Video Experts
Robert Rankin
matthew walsh
Level 1 Expert
Tom Chichester
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
