Question about Gaggia Baby Espresso Machine
Low water flow from gaggia evolution only 6 months old, have tried descaling, no obvious scale found in machine. pump starts but goes quiet, very feeble flow of water.
  • 1 more comment
  • edgarpacia Jul 15, 2008
    1. The pump is working (sounds like)
    2. I saw 4 outlets but one working but slow sometimes bubbles.
    3. The 3 outlets not working.
    4. Tried to put White vinegar to remove scales (Still not working)
    5. Any solution please let me know (from Toronto Canada)
  • Roger Jackson
    Roger Jackson Aug 19, 2008
    I have a Gaggia TEBE (Baby in disguise?) and all appears to work except there is no water coming out of the group head. Behind the spray plate there are four holes, of which one bubbles slightly but the others are dry. I descaled it using Gaggia descaler with no effect. The steam pipe works fine but it back-flushes the water to the tank from the group head and the pump sounds like it is working hard as if the water cannot get through.
    I guess it is scaled-up inside the group head so I tried to dismantle it but having removed the two Allen screws it will not come off. I applied descaler to the head and cleaned it thoroughly but it still will not come off, even if I apply leverage with a large screwdriver (as advised somewhere else on the web).
    I am now pondering my next move and any help would be appreciated.
    Roger Jackson
  • Anonymous Mar 24, 2014
    The flow time for 2 cups can take up to 60sec but sometimes it will take the correct 20sec. I have backflushed with cleaner tablets stripped the head, left all the parts soaking.That seemed to work but after afew days it was back to its bad old ways.I have very soft water so scaling is'nt a problem.
    Hope you can help.
I have now solved this problem. The lack of flow associated with the pump working but running quietly is caused by the Group Head being blocked with limescale. Normal descaling cannot remove it because it cannot penetrate the Group Head.
Removing the Group Bell can be achieved using a collection of screws (see photo) and works no matter how stubborn the thing: levering it with a screwdriver in my case was impossible as it was so well glued on. low water flow from gaggia - 6d47425.jpg
I figure that the advice to replace the rubber seal once per year is a good one because it forces you to remove the Group Bell and clean it out.
Posted on Aug 20, 2008
  • mysticMart Dec 29, 2010
    Thanks a lot! After removing the Group Bell it wasn't obvious it was covered in scale because there was to much of it. But it's now working like new!
  • anita117 Mar 14, 2011
    Hi, I have the same problem you had but for the life of me I can't get the group head off. I see you managed it with the screws, but even looking at the picture, i can't see how. Any chance you could explain please?
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Gaggia Titanium - can't get it to move beyond 'Ventilate.' This started as a problem with extremely slow coffee output. We've been good about de-scaling but brought it into a repair place who cleaned it...
Select "Hot Water" and open the steam valve. Let it pump water out the steamer for awhile. It usually clears right away but may need to pump a lot of water to clear the error.
If you aren't able to get any water coming out the steam nozzle, you may need to prime the pump with the little squeezy tool they gave you with the machine - or you can use a turkey baster. Mainly you are trying to get water up into the pump to prime it (get the air out of the pump) so it can pump water instead air.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
I have a Gaggia Titanium that is six years old. I descaled for the first time and went through the entire process.. After it rinsed I put it all back together. When I flushed the steam wand, some nasty...
HI Sorry, but you have 6 years of scale that has been broke loose and is now plugging your lines. You are going to have to take you machine apart and blow out all your lines and also the boilers with air pressure to clear the lines. Descaling is one of the most important things you can do for your machine. Your lucky that your machine went 6 years. Most don't.
Jan 25, 2010 | Gaggia Titanium Espresso Machine
I don't have enough water pressure to make cofee. Very little water comes out of the shower head. The shower head is clean, it is not plugged. I suspect it is the pump? Please advise
I had the same problem: clean showerhead, machine pumps hot water just fine, but very little brewhead flow. Descale made it worse but that was a big clue! I took apart the brewhead and found grains of scale in the boiler, like pulverized beach shell:
Some of those bits apparently made their way into the three way valve and clogged it. I could not blow air through the channel between the plunger and the boiler. Not surprising: the inlet hole inside the valve is TINY and clogs easily.a0bc8304-2405-4fdb-a444-21cf80e7701a.jpg
Once I got this part cleared up inside (and cleaned out the rest of the scale from my boiler so it didn't immediately re-clog!), my brew flow was restored.
Sep 05, 2009 | Gaggia Classic Espresso Machine
I have a Gaggia Evolution expresso maker about 8 years old. When button is pressed to start motor it just hums and no hot water comes out. The motor only runs if I open the steam outlet
Try this, under the grouphead, there is a screw and screen, remove those, and check screen to see if it is clogged, when screen is removed press button to brew, if water flows freely then problem is at the screen, if no water flows, then it is on the inside of the machine. You will have to run a descale cycle to clear out machine. Check the folling pic for the screen location.2722dbe.jpg
Jun 27, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Feb 27, 2009 | Gaggia Evolution Espresso Machine
Gaggia evolution- water doesnt flow through the brewer
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Feb 23, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Classic Espresso Machine - will not pump water
Hi, this is so easy to fix. Firtsly unplug the machine. Then remove the two screws in the top plate so that you can have access to the internals of the machine. You will see the red pump to the left hand side at the back. Remove the two screws that hold the pump in place (use a magnetic screwdriver so that you can pull the screws out). Pull the pump up towards you and then unscrew the thin plastic pipe at the top of the pump . It is the pump that has the scale build up problem. If you the put the water tubes into the water tank and hold a cup to the top of the pump to catch the water you then have to switch the pump on. You will then start to see lots of scale come out of it and the pump will pump more water than you are expecting so be careful. Be sure to cover the internals of the machine whilst you are doing this as you don't want to get water on the electrics and electricute yourself!!! Then rebuild it! Just svaed yourself £100 in having it serviced :-)
Feb 14, 2007 | Gaggia Classic Espresso Machine
Gaggia Baby Espresso Machine Logo
2,143 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
