Question about Proscan PS32500 32" TV
No sound my tv will not produce any sound,we have sound when the dvd/video is beeing played but not on the tv.I do believe it has something to do with the remote,because i think my son sat on it when this problem started. i have a proscan PS32700YX1.
  • Mikial Rashad
    Mikial Rashad Apr 29, 2008
    question how can I have a fail when if playing a VCR tape we hear the sound not Dvds and TV. What is SAP?
    Genius:
  • Proscan Master
  • 1,673 Answers
Go in to the menu for the sound setup. Make sure that the sound is not on MUTE, or SAP. Make sure that the speakers of the TV are in the ON mode, or any sound system that the set feeds is setup okay for the TV.
It is possible by coincidense that something in the audio section of the set has failed.
All of this has nothing to do with sitting on a remote control...!!!
Jerry G.
Posted on Apr 29, 2008
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Viore 42 inch tv PD42Vh80 had no sound but great picture HDTV
speakers switched off?
volume on set or a box down or muted? check both the set and box.
Does the set have normal sound when playing a DVD etc via the audio and video jacks on the rear or side?
Apr 29, 2012 | Toymax Viore 42 in. Plasma TV
Dvd player resolution
what exactly does it say? that sounds like more of a tv setting...changing from 1080p to 720p or trying to play a blue ray in s standard player. Hmm..you need the programming codes for your remote. keep googling them...try these 1st... intertek is same as GPX i believe
0449, 0405, 0446 or 0936, 0944, 2114, 2390
*Remote program codes
Aug 30, 2017 | Televison & Video
My color TV has turned black and white however my DVD that is plugged into the receiver plays in color. What's going on?
When one asks questions involving two components it is always necessary to know the identity of both. "Color TV" is kind of generic.
Please define the TV and which direct video input on IT produces B/W and exactly how it is connected and from what specific source unit. Then try swapping something that works, say, the DVD, into the "B/W" input to see if that helps.
If you're using component video cables you could have one loose or defective.
Mar 25, 2010 | Sony STR-DE675 Receiver
DVD's not playing in color
sounds like the problem is the TV . your tv have to different inputs , COMPONENT is for the separate color , BLUE , RED , GREEN this is for better video quality , if your DVD doesnt have this OUTPUT feature , then maybe the YELLOW (VIDEO) , RED & WHITE ( AUDIO ) thats coming out from your DVD player is connected to the COMPONENT input of your TV , GETTING the B&W effect. it should be connected to the VIDEO input of your TV ( yellow , red , white ) hope this is helpful AJ
May 03, 2009 | Philips DVP3140
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
No sound from video captured through the handycam
use a cable to connect the line out of the card to the line in in your sound card. make sure line in is selected as the recording source.
Jan 06, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Proscan PS32500 32" TV Logo
113 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
