Replaced the CPU on my K7 Triton GA-7VKMP MB with VIA KM266 chipset. The new CPU is an AMD Athlon XP 2200 1.8Ghz Socket A 266FSB w256KB processor (OEM). Pin #1 golden cut edge is installed correctly. Symptom: The computer now displays black screen and keeps beeping every second or so and does not boot up.
  • electrc Apr 29, 2008
    I discovered the 256M RAM was not installed firmly into its slot. I removed it, reseated it, locked it in and now the computer is running like new.
    Mahalo all for your suggestions.
    Aloha,
    Stan
  • 56 Answers
Did you check if the new chipset is compatible with the MB? If they are, are you using the same hard drive? If so, there is the problem. You will need to format the hard drive and reinstall the OS so it uses the correct drivers. Dont forget to have your license key for the OS available. You will loose any info on the hard drive, hopefully you had it backed up...
Posted on Apr 29, 2008
    Scholar:
  • 160 Answers
For Solving your problem do the following:
1. See that the RAM is placed correctly.
2. Remove the RAM, clean the surface and ram surface
3. Place the RAM safely and correctly
4. See that all the power cables and data cables are fixed correctly
Let me know if your problem is solved and rate me as FIXYA!
I'm upgardeing my ms-7061's cpu from a 1.5 to 2.2
http://www.msi.com/product/mb/KM4M-V.html#/?div=Detail
Download > Manual >
CPU
Supports AMD Athlon / Athlon XP / Duran (Socket 462) processor.
(Socket 462 = Socket A)
Supports from 1100MHz to 3000+ model.
VIA KM266 Pro motherboard chipset - Front Side Bus support of 266MegaHertz.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
(Same specs as a VIA KT266A but with Integrated Graphics.
The 133MHz FSB support shown is doubled. AMD processors are 'Double-pumped')
VIA KM400 motherboard chipset -
FSB support of 266MHz to 333MHz.
(Same as KT400 but with Integrated Graphics)
VIA KM400A motherboard chipset -
FSB support of either 266MHz, 333MHz, or 400MHz
(Same as KT400A but with Integrated Graphics)
Looking at the Bottom/Right corner at the CMOS battery;
There are THREE sets of jumper pins to the bottom right edge of the CMOS battery.
6 pins towards the outside edge of the motherboard, 3 pins to the inside of the motherboard. (Left side of the 6 pins)
On the 6 pins in a row configuration, the top 3 pins is SW1.
The bottom 3 pins is SW2.
The 3 pins to the inside of them is JBAT 1
In the 3 pins for SW1 the bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Same for SW2. The bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Jumper on pins;
SW1 pins 2 and 3, SW2 pins 1 and 2 = 266MHz FSB support
SW1 pins 1 and 2, SW2 pins 1 and 2 = 333MHz FSB support
For the KM400A (KT400A) motherboard chipset;
SW1 pins 1 and 2, SW2 pins 2 and 3 = 200MHz FSB support
1) What is the model name, and model number of the AMD processor you are going to use?
2) What kind of Thermal Paste are you using?
3) What are you using to clean the bottom of the Heatsink with, and is the top of the Processor clean?
4) Are you following Anti-Static Precautions?
Post back in a Comment.
Regards,
joecoolvette
Oct 13, 2012 | Computers & Internet
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
What is the fastest cpu I can put in my GA-7IXE4? PS: I presently have an 800 MHZ cpu installed. Thank You in advance.
Anything upto an AMD K7 Sempron 3000+ and will also take upto 768 Mb of sdram memory ....cheers from Scott
Sep 05, 2011 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Ga 7vm400am motherboard
yes they are both 462 pin socket a processors and you have a socket a motherboard
Apr 30, 2010 | Computers & Internet
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
K133ASA via Apollo motherboard cpu upgrde
Socket A/462 can take any AMD K7 family processor. The fastest you could get would be the Athlon XP 3200 I believe, but that could also include the Athlon 1400 and the Duron 1800. So it looks like you can make a significant upgrade of yhe processor.
Jan 28, 2009 | Computers & Internet
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Computers & Internet Logo
David Payne
David Payne
