Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
It Wont turn On
I have barely used my tv and now it wont turn on. I removed the back cover and the fuse was ok. still wont turn on what do i do?
  • 4 more comments
  • GingerCS May 04, 2008
    The same thing happened to mine - one hour it was working and I was watching a movie, and when I went back to turn it on and finish the movie, it wouldn't do anything.
  • awacman May 08, 2008
    I have the same problem. The tv worked fine and then was left off for several months. When I tried to turn it on, Nothing. Checked fuse ok
  • nefferoo Sep 06, 2008
    We have had this tv in a box for 2 years and opened it for the first time and it will not turn on
  • sbelisborg Oct 03, 2008
    We moved our Mag Combo to a adjoining room and tried to turn it on, absolutely nothing. I don't know how to check the fuses on a tv. Can someone help me.
  • cmsully33 Oct 05, 2008
    I have plugged it into different outlets but it won't turn on at all. What can I do to fix it
  • shadar Apr 25, 2009
    The TV was working just fine, we were watching a show and I went to turn the volume down and the remote didn't work, I got up to lower the volume manually and it still didn't do anything. Kinda annoyed! Now we unplugged it and plugged it back in and nothing works, won't turn on at all!
I have the same problem with my MWC20T6A (from Walmart), and I keep blowing fuses. I read somewhere that it's in the motherboard which is about $150 to fix. I'll never by a combo again.
Posted on Jun 28, 2008
    Problem Solver:
  • 5 Answers
Tell me more/eg.your experience to hand with fault finding and ill know how to explain a possilbillity
Posted on May 28, 2008
Went bang tripped fuse now wont turn on
Did you flip the switch in the switch box back on?
Dec 26, 2013 | Kitchen Ranges
1998 dodge ram 1500 dash lights wont work
Walker Muffler - Aluminized Steel Direct OE Replacement 1998-2001 Dodge Ram 1500.-------------------------------------------------------------------------------------
SLIM HID XENON light
Jan 10, 2013 | 1998 Dodge Ram 1500 4WD
Tv wont turn on
tried to unplug the tv for a while to reset the power supply and then re plugged and turn it on let see if it will turn on. if still doesn't work and no power at all, at this time you will need to remove the back cover to access the power supply board, then look for a bad fuse or a burnt parts. replaced bad parts with the same value and rating.you can find replacement at www.digikey.com.
Dec 24, 2012 | Emerson LC195EM9 19 in. LCD TV
No power coming from the TV, it wont turn on
The first thing would be to unplug set and remove back cover, follow power cord to fuse-----check the AC line fuse and if bad replace it.
If that fuse is good let me know if power light does or does not come on at the front of the set.
Mar 13, 2012 | Hitachi 55FX48B 55" Rear Projection...
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
Motor stopped spinning. it will barely turn in the counter direction, but wont turn at all in the right direction!
you have a motor/bearing problem. UNPLUG tool and turn on its backside and remove the back motor cover and see if the bearing has collapsed. and remove brushes to see if motor burnt
Aug 25, 2010 | Bosch 4000 - 07 Electric Table Saws
I was wathing tv when my light started flickering then the tv turned off now it wont turn back on please help
Hello, This is a sudden high voltage, it will require opening the television to check faulty component. First check for fuses in the printed circuit board and if found replace with same current rating. Also check other component such as the power transistor, resistor, rectifier with a multimeter set at ohms range
May 20, 2010 | Televison & Video
Instruction to replace fuse philips 32mt3305/17 quit working after house power surge wont turn on
The internal main A/C fuse is usually located within close proximity to the power cord entry point on the main PCB. So remove the back cover and follow the cord to something that looks like this.
Nov 06, 2009 | Philips 32MT3305 TV
RADIO WONT TURN ON
hi first thing to blow will be the fuse try looking in your fuse box if that is ok remove your radio it will proberly have a in line fuse fitted on one on the back of the radio if you cannot see them check there is a live going to the radio if so take the radio cover off the fuse will be inside yates210456
Oct 08, 2008 | 2000 Audi S4
Jammed papler
inspect your fusing unit carefully, do not use any sharp things, you can damage the fusing roller. see that the sensor is moving fine, that the separator are OK, not broken.
if thats not helping and you wont find anything, last thing is remove back and side covers, carefully remove TBU, unhook the connectors and remove two screws in fuser sides and remove fusing unit to inspect it a little closer.and find the problem.
Mar 21, 2008 | Konica Minolta magicolor 2400 Laser...
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
457 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
