MY PRINTER COLORS ARE NOT PRINTING RIGHT THEY ARE ON THE PINK SIDE AND I PUT ALL NEEW CARTRIDGES.
  • 26 Answers
Try doing a head clean through the printer utility .. and do a test pattern
Posted on Apr 29, 2008
I have replaced all ink cartridges n black will not print n when I change it to colour it prints everything in pink
The color combinations (order?) of different printers are not the same. Make sure that you have the right cartridges for your printer.
Mar 08, 2015 | Office Equipment & Supplies
Need to find out how to put ink cartrdiges back into hp 5610 all in one printer.
First, turn the printer on. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right Pull the print cartridge toward you out of its slot.
Now we're ready to install the new cartridge. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket. Close the print-carriage access door.
Mar 21, 2011 | HP Officejet 5610 All-In-One InkJet...
Ink is stuck in the printer. I can't get it out.f4280 deskjet
I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
To replace the print cartridges
1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
2. Open the print cartridge door.
The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black print cartridge
4. Pull the print cartridge towards you out of its slot.
6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing the black print cartridge, slide it into the right slot.
Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
MP 160 IS PRINTING ONLY BLACK AND PINK COLLORS
Maintenance your cartridge with head clean or deep clean. If you don't get full colour, then change the colour cartridge.
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
The printed pages have pink blotches on the right hand side of the paper and horizontal pink blotches down the page
Try cleaning the color or magenta cartridge with rubbing alcohol and look inside the printer to see if there's pooled ink anywhere that is smearing on the paper. Try replacing the print head or cartridge.
Sep 17, 2009 | Lexmark Office Equipment & Supplies
Color looks pink and washed out (even after changing ink cartridge)
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost..
May 18, 2009 | Kodak ESP 5 Printer
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Computers & Internet
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
May 11, 2007 | HP OfficeJet t45 All-In-One InkJet Printer
236 people viewed this question
jasbo
jasbo
