Question about Dryers
Whirlpool Dryer 4 year old dryer takes too long to dry (Whirlpool) Already checked for: Clogged exhaust from house (professionally vacuumed) Exhaust Extension Pipe bent or clogged from dryer to house exhaust pipe If we disconnect the exhaust hose from home exhaust pipe and direct it to the Garage, the dryer works fast and furious. If we hook it back up, dryer takes two cycles to dry clothes. When we purchased home 4 years ago, builder covered vent during landscaping process as the vent came out of the slab. Builder fixed via extension directing pipe above ground. We always thought it took too long to dry clothes and thought this is how the dryer worked. The test we performed via exhaust direct to garage proves dryer works much faster than when it is connected to the exhaust outlet/vent from our house. Out of ideas, please help!
    Problem Solver:
  • 6 Answers
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Posted on Apr 29, 2008
Whirlpool dryer times jump on high temp from 50 to 29 takes three cycles to dry cloths.
Check that the heating element is working. Then check the exhaust flue of dryer to make sure that it is not clogged. If it is the clothing will stay damp and the room housing the dryer will get hot and muggy.
Oct 27, 2016 | Whirlpool Dryers
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
Dryer takes twice as long to dry clothes.
Did you check the outside vent? Those get clogged as well.
Oct 27, 2012 | Whirlpool LER7646J Dryer
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My dryer seems to take much longer to dry clothes or towels. Which part needs to be replaced?
Hello there:
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Oct 05, 2010 | Roper REX3614KW Electric Dryer
Dryer takes long time to dry. usually 2 or 3 cycle. Filycter is cleaned after every cycle. Vent hose is not blocked
This complaint usually is attributed to clogged exhaust venting somewhere. As a process of elimination, remove the exhaust venting from behind the dryer and run your loads. If the dryer dries clothes properly, then your issue is definitely with the exhaust venting (e.g.: inside wall, attic, etc.). If possible, check the entire path of exhaust venting or contact a vent cleaning company.
Apr 14, 2010 | Whirlpool LEB6300 Electric Dryer
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet GGW9250PW2 not drying effectively. We run on more dry setting.
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Dec 22, 2009 | Dryers
Dryer isn't drying
Your dryer has some internal ductwork that can get clogged and prevent the dryer from operating efficiently. In most dryers it takes quite a bit of disassembly to get to the internal ductwork. Take out the lint filter and look into the opening with a flashlight. Clean out as much as possible with a vacuum cleaner. Also check the venting to the outside. Make sure that the vent is not clogged up and that the flap on the exhaust vent on the side of the house is not stuck closed or partially closed. I will assume that the heating element is working and that the dryer is heating up. If not, that would indicate another issue. Sure hope this helped ya and best wishes.
Jul 23, 2009 | Whirlpool LEN2000PW Dryer
Water in my Whirlpool Front Load Dyer exhaust..
Greetings ireneosanch,
Has it been taking longer than normal for your dryer to dry the clothing also leading up to this? Sometimes your ventilation can become so clogged that it will cause condensation to accumulate in the exhaust hose. I would check the vent on the outside of your house and see if it is clogged and you might also have to have the actual ventilation cleaned out leading through your house.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
172 people viewed this question
Top Dryers Experts
