GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Aug 11, 2010
How to check a magnatron in a microwave Microwave runs but does not heat
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
Helped
1355
Points
34
Use the amper meter or clamp meter ,magnatron heck first physically then check coil continuty check the HV diode&pcb also
GE microwave runs,mag runs but no heat mdl je1140/1142
It is due to missing HT supply to magnatron or faulty magnatron,you can also check by replacing HT diode for the same.
Maytag microwave is not heating and the time runs back fast.
Hi, it sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnatron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnatron, they replace the whole oven.
There is a possiblity that the circuit that provides power to the magnatron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it appart. It is a fairly lengthy process however.............
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
My GE spacemaker II microwave won't heat what can I do
The main internal component of your microwave oven is called a magnatron. This is the device which generates the microwaves that heat your food up. If your oven appears to be working properly but it's not heating the food, it means the magnatron is not generating microwaves. It could be faulty itself or it could be a component linked to the magnatron. (high voltage capacitor) etc.
Have this component checked by a qualified technician.
Let me know if I can be of any further assistance.
Best wishes,
Graemevm
1helpful
Microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
2helpful
MSS3444DPS
There is a device in your microwave oven called a magnatron. This device generates the microwaves which heats up the food. If all is working but there is no heat, it means the magnatron is faulty or perhaps part of the magnatron circuitry. Check all fuses and then have the magnatron tested by a qualified technician if all fuses are okay.
Please let me know if this has helped solve your problem.
Best wishes,
Graemevm
2answers
Regarding microwave
Sanjay
This is due to the magnatron failing (this is the part of oven that cooks the food!) This is the most likely cause of y isssour oven not heating the food!
Magnatron needs replaced for oven to work again!
Please rate this free soultion!
Quit heating
This is a sure sign that the Magnatron has burnt out and needs replaced ( This is what cooks the food!) Replace magnatron in oven unit and all should work well!
Please rate my response!
THANK YOU!
Microwave won't heat
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodesmag-glass_10x10.gif, and capacitor
1helpful
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
