Question about Ricoh Aficio CL2000N Laser Printer
Lines down page
What could be wrong if there are white lines down the page
  • Ricoh Master
  • 2,794 Answers
This happens when the PCU (Printer Control Unit) is bad. You can contact Ricoh for a new one. Depending on the useage of the unit it could be covered under warranty.
Posted on Jun 06, 2008
My luxor smart tv gives me a blank screen with a white line when i go on the internet
What was wrong with your tv? Did you get it away? I am having same issue
Apr 06, 2014 | Luxor Televison & Video
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Two white gost lines in the middle on the middle of the page ( one two millimeters wide) , the other 2cm away and one ml wide with shadows There are several other with similar distance from eacjh other but...
Something is wrong with your printer -- part of the drum is *NOT* holding the magnetic-charge that the laser should be creating. So, none of the ink "sticks" to the paper, resulting in a WHITE strip.
Take the printer to a qualified technician, for proper trouble-shooting & repair.
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
1/2" white line appearing down right side of page
Try replacing the toner cartridge. This seems to be a problem with the photo-sensitive drum, which is located in the cartridge.
Jan 05, 2010 | Dell 3100cn Laser Printer
I am getting a white line on my pages that go from the top of the page to the bottom. What could cause this?
A line all the way down the page means you have something blocking the imaging module like a bit of dirt or a piece of torn paper. Look in the area where the white line is, or it also could be toner being scraped off the page near the fuser, in that case you may see a smudge next to the line.
Dec 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
White line down side of page when scanning
I chatted with HP and they told me to clean the ADF frame which had some dust particles on it. Problem solved.
Jul 23, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
Ricoh Aficio CL2000N Laser Printer Logo
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
