Sound Problems with JVC AV-35BP4 TV
The internal speakers on my JVC AV-35BP4 TV are not working, nor can I get TV sound out of the external speakers I have hooked up through my receiver. I know the reveiver/speakers work because other applications run through the receiver work fine.
There is an EXT SPKR switch on the back of the TV and I've tried it in all positions...still no sound.
Any ideas?
I have aPS32700yx1 proscan tv.The sound works when we play videos and dvd's but when we watch tv there's no sound.
    Genius:
  • Televison & ... Master
  • 1,689 Answers
The audio output stage for the speakers may have failed in the TV set. If the set has an earphone jack, it is also possible that the jack has a fault (very rare, but I have seen this).
Are there external speaker outputs to try other speakers?
Jerry G.
Posted on Apr 29, 2008
The volume dont work it shows on the screen going up and down but no sound. i checked the speakers and they work what could it be
Your internal speakers may be shut off, go into your menu, go to sound, look for an internal or external audio setting. If internal make sure it is on, if external make sure it is off
Jun 25, 2011 | JVC AV-48WP30 48" Rear Projection...
The sound on my tv is off and i dont know how to turn it on?
some tv's have a button on the back that will turn on or off the built in speaker system so that the tv can be plugged into an external system and allow the user to use the tv's volume control for the ext. speakers without hearing the internal ones, if there is no such button check the tv's setup menu for a setting that enables or disables the speakers
Jan 22, 2011 | JVC AV-27320 27" TV
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
Hey, my old tv blew out so i plugged in my tv in the kitchen to my bedroom. It is an older jvc television. It worked fine for a few days then the sound just quit working one night. I have messed with it...
Recheck all AV cables connections?Common problems,take all the AV cables connections aparts and clean it replug it in or AV cables are damage and shorted,change the AV cables.
Oct 11, 2010 | Televison & Video
No sound or input
You have the center sound on in your menu, just turn off the cneter sound option and it will all come back on
May 14, 2010 | JVC AV48P777 Television
AV-2053m
My problem is solved!!! I called my neighborhood TV repair shop. The technician suggested I check the Internal Speaker Switch on the back of the TV. And sure enough, I had accidentally move the switch to the OFF position while carrying it from one room to the other. Ahhhhhhhh!!!!!!!!!!!!! my 13 year old JVC is as good as new!!!!!
Aug 02, 2008 | JVC AV-32260 32" TV
Hi there!
The amplifier section may be at fault. Could also be IF or dry joints in that area. Also check the speakers(Highly unlikely though) Good Luck,JUS004
Feb 24, 2008 | Televison & Video
Lost sound on JVC TV
http://www.amazon.com/JVC-AV-48WP30-Widescreen-HDTV-Ready-Rear-Projection/dp/B000066R7X
Cut and paste this link. Amazon's page has a link to the JVC manual. That'll tell you what you need to know
Jan 21, 2008 | JVC AV-48WP30 48" Rear Projection...
I have picture but no sound
go into the audio menue to turn speakers back on
Dec 27, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
