Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi tv sound is out
The sound on my tv has gone out for some time now. On a rare occasion it actually comes back but in between long periods of time. I live in a very rural area and the minimum charge to come out and service is 200 hundred dollars and then 80 per hour. Is it something simple or would I be better off purchasing a new model.
  • 78 Answers
If your tv is very old (ten years is old in tv years) then you would be better off with a new one. your alternative would be to run a pair of audio cables from your vcr or cable or satellite reciever to a stereo using the auxillary input and adjust your volume with the stereo.
Posted on May 02, 2008
I have a hitachi l42vk10u and the sound has stopped working this has happend before and the technician went into advanced menu the sound has now gone again
Switch off the TV at the wall plug and pull the plug out. Disconnect everything from the TV, wait 5 minutes, reconnect the aerial, put the wall plug back in and switch on. You should now have sound. I`ve had this on several occasions and this always solves the problem.
Jan 26, 2014 | Televison & Video
My Hitachi TV has gone black
Chances are you have either a bad X SUS board, a bad Y-SUS board or bad Power Supply. In the worst case possibly all three.
I a very rare occasions I have seen the Plasma Panel cause on or more of the above boards to fail. The only way to find out is to call a professional to verify. I would not recommend going it alone.
I hope this helps,
Skyassoc
Jul 19, 2009 | Soyo DYLT032C 32 in. LCD Television
OK friends. You've helped me with a TV once before. Now I need your help again. I have a 55 inch Phillips rear projection. Model# 55PP970104 Serial# 58610822 Chassis Model# DPTV210 born on 6-13-01 I bought...
sounds like loose solder or crt board...hard to say.
I have the exact set in the shop - same problem - but I have not gotten around to playing with it...
Mine does the same...warms up - works...
Email www.TvRepairKits.com - they may be able to help.
Ed
Jun 10, 2009 | Philips 55PP9701 55" Rear Projection...
Hitachi 65F710 tv goes blank for a second...
sounds like a possible flex module problem. repair is usually abut $500- $600.
Apr 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Large black box keeps covering 80% of the screen
i have the same problem, when i turn the volume knob on hitachi remote it goes away. Anyone heard of thi s???
Aug 30, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Projection TV problem
sounds like the vertical deflection is causing the CRTs to blank cause you still have sound and on screen displays. Try resoldering the vertical output IC see if that helps. If not you may need a new vertical output IC. Let me know if i can assist you further.
Apr 04, 2008 | Hitachi 51F510 51" Rear Projection...
Screen image goes out
sounds like a problem or cold solder connections in the video section or b+ vlotage missing muting the video.
Mar 30, 2008 | Hitachi 51F510 51" Rear Projection...
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Hitachi TV
May have a CRT going south on you. This is actually a more common problem than once thought...accordianman
Oct 11, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
63 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
